BT.com
Wishlist
CoolerMaster Jet Flo Red LED PWM 120mm Fan
Delivery
Standard Due date unavailable
Performance, style and silence - everything you want in a fan has been included in the JetFlo 120. 7 ultra-thin yet rigid blades generate high airflows that reach up to 95 CFM. Steel threaded rubber pads absorb fan vibration and keep the noise down.
Cooler Master JetFlo 120 - case fan
Case fan
Package Content
4 screws, 2 silent mode adapters (1600/1200 RPM)
Red
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
4th generation bearing
Rotation Speed
800-2000 rpm
Air Flow
95 cfm
Noise Level
36 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Red LEDs, reverse polarity protection
Product Material
Rubber
Water-resistant, dust-resistant, shock absorption
Case fan
Product Material
Rubber
Package Content
Red
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
800-2000 rpm
Air Flow
95 cfm
Air Pressure
2.72 mm
Noise Level
36 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.4 A
Power Consumption
4.8 W
MTBF
160,000 hour(s)
Scroll to top
