BT.com
Wishlist
CoolerMaster Hyper 412s - 4 Heatpipe, Tower CPU Cooler
CoolerMaster Hyper 412s - 4...
£41.52
£41.52
Add to wishlist
Delivery
Standard Due date unavailable
The Hyper 412S CPU cooler is designed for optimum heat dissipation at low fan speeds. This is thanks to wider fin gaps and a precise heat pipe layout that directs each of their four heat pipes across CPU "hot zones". These heat pipes are arranged using Cooler Master's patented CDC technology, creating a virtual vapor chamber for maximum cooling potential. The 412S comes equipped with an ultra low speed silent mode fan adapter to virtually erase noise levels.
Cooler Master Hyper 412S processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket
Heatsink Material
Aluminium and copper
Fans Qty
Dual
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Plain bearing
Rotation Speed
1300 rpm
Air Flow
36.4-52.6 cfm
Power Connector
3-pin plug
Heat pipe technology, Heat Direct Contact (H.D.C.) technology
13.2 cm x 9.9 cm x 16 cm
0.5 kg
Processor cooler
13.2 cm
9.9 cm
16 cm
0.5 kg
Heatsink & Fan
Compatible With
Processor Compatibility
Core i7 Extreme Edition , Core i7 , Core i5 , Core i3 , Core 2 Extreme , Core 2 Quad , Core 2 Duo , Pentium , Celeron , Phenom , Phenom II , Phenom X3 , Phenom X4 , Athlon II , Athlon X2 , Sempron
Heatsink Material
Fans Qty
2
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Plain bearing
Rotation Speed
1300 rpm
Air Flow
36.4-52.6 cfm
Air Pressure
1.4 mm
Power Connector
3-pin plug
Power Consumption
1.2 W
Sound Emission
22.5 dBA
Scroll to top
