BT.com
Wishlist
CoolerMaster HAF-X Full Tower (Extended ATX) Black
CoolerMaster HAF-X Full Tower...
£160.36
Hurry, only 1 left in stock!
£160.36
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, graphics cards and is even compatible with USB 3.0 devices. With specialized support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this as close as it gets to a system builder's 'dream case'.
  • SATA Dock for easy installation without the need of removing side panel
  • Internal USB 3.0 on front I/O panel
  • Air duct to cool the latest graphic cards
  • Up to 1 x 230 mm red LED fan and 3 x 200 mm fans
  • 9 slots support triple VGA cards
  • Adjustable VGA card holder to support heavier GPU cards
  • Power supply partition to conceal cables
  • Advanced cable management with rubber grommets
  • Spacious interior for larger component parts
  • Rugged black coated interior
Cooler Master HAF X - full tower - extended ATX
System cabinet
Full tower
I/O Connectors
4 x USB , 1 x FireWire , 1 x eSATA , 1 x audio line-out , 1 x microphone
Installed Fans Qty
4
Supported Motherboards
ATX, microATX, Extended ATX
System Cabinet Features
Windowed side panel, Red LED
Specification Compliance
ATX / PS/2
23 cm x 59 cm x 55 cm
14.35 kg
Full tower
Max Mainboard Size
Extended ATX
ATX / PS/2
Internal Bays Qty
5
Front Accessible Bays Qty
8
Fans
Front: 1 x 23 cm - (1 installed) , Top: 2 x 20 cm - (1 installed) , Side: 1 x 20 cm - (1 installed) , Rear: 1 x 14 cm - (1 installed) , Internal: 1 x 12 cm - (0 installed) , Internal: 1 x 8 cm - (0 installed)
Expansion Bays
6 (total) / 6 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x front accessible - 2.5" , 5 (total) / 5 (free) x internal - 3.5"
Expansion Slots
9 x Expansion Slot
4 x USB , 1 x FireWire , 1 x eSATA , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
23 cm
59 cm
55 cm
14.35 kg
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* what a beast
Reviewed by kikassridec2 on 07/11/2011
when it arrived i just couldnt believe the sheer size of this thing its a beast! instalation took 2/3 hours cable management is fantastic a solid built chassis with so much room to play with made my 430 case look midi ;) loads of front ports to lay with even thoe not all is needed for me to that helped with cable management even more huge size fans keeping my machine at 25c chassis temp cup at 40c idle 42 full load. fans easily swappable if u want to swap standard over for led to match the front fan like i have done and must say gives off a deep red nice glow to the inside of the case so i do enjoy peeping through the clear window to admire my build ;) lil pricy at the end of the day is why im giving it 4 stars and not 5 this case is real heavy i believe 30lb and thats empty so even heavier once full loads of accessories came with it screws,bolts,cable ties, ect also feet but this thing is tall enough without adding the feet to it lol.
Scroll to top
