Click to visit BT.com
BT.com
Wishlist
Coolermaster Elite 430 Black
4.0*
Quicklinx: 7B18WS00
Mfr#: RC-430-KWN1
The Elite 430 Black was designed with all-black interior coating with the main purpose in mind to give enough space for large graphics cards, no matter what your brand preference is. The Elite 430 Black also features plenty of cooling options and a well ventilated front mesh design to keep even the hottest system cool.
Speciification
  • Model RC-430-KWN1
  • Available Color Black
  • Material Steel Body; ABS plastic
  • Dimension 190 x 424 x 490 mm / 7.5 x 16.7 x 19.3 inch
  • Weight Net Weight: 4.7 kg / 10.3 lbs
  • Motherboards ATX / Micro-ATX
  • 5.25" Drive Bay 3 Exposed
  • 3.5" Drive Bay 5 Hidden / 2 Exposed
  • I/O Panel USB x 2, Mic x 1, Audio x 1
  • Expansion Slots 7
  • Cooling System Top: 120 mm fan x 2 (optional)
  • Front: 120 mm blue LED fan x 1, 140 mm fan x 1 (optional)
  • Rear: 80/90/120 mm fan x 1 (optional)
  • Side: 120mm fan x 1 (optional)
  • Bottom: 80/90/120 mm fan x 1 (optional)
  • Power Supply Standard ATX PS2 (optional)
Cooler Master Elite 430 - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 2.0 , 1 x microphone , 1 x audio line-out
Installed Fans Qty
1
Supported Motherboards
ATX, microATX
System Cabinet Features
Windowed side panel
No power supply
Specification Compliance
ATX / PS/2
19 cm x 49 cm x 42.4 cm
4.7 kg
Mid tower
Max Mainboard Size
ATX
ATX, microATX
ATX / PS/2
Internal Bays Qty
5
Front Accessible Bays Qty
5
Cooling System
Top : 120 mm fan mount x 2 , Front : 120 mm fan x 1 / blue LED , Front : 140 mm fan mount x 1 , Rear : 80/90/120 mm fan mount x 1 , Side : 120 mm fan mount x 1 , Bottom : 80/90/120 mm fan mount x 1
Windowed side panel
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 2 (total) / 2 (free) x front accessible - 3.5" x 1/3H , 5 (total) / 5 (free) x internal - 3.5" x 1/3H
Expansion Slots
7 x Expansion Slot
2 x USB 2.0 , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
No power supply
Max Supported Qty
1
19 cm
49 cm
42.4 cm
4.7 kg
Customer reviews
Write a review for the Coolermaster Elite 430 Black here!
great case
Reviewed by Anonymous Review Posted 10/03/2012
brilliant case for the money, only problem i had was the front 5.1/4 inch bab panel came off but it makes no difference to the function so i can't complain.
  • Overall 5*
  • Ease of use 4*
  • Value for money 5*
Great Case
Reviewed by Anonymous Review Posted 17/07/2012
Easy case to work with and for that price it cant be beaten!
If your wanting a budget case then go no where else for one.
  • Overall 5*
  • Ease of use 5*
Great value case!
Reviewed by Evan Wilson. Review Posted 02/09/2012
A great overall product, though the box looks a bit cheap, the case feels quite cheap, and the cable management (as others have repeatedly said) is non-existant.
That all being said... this case costs the same as dinner in a decent restaurant, and houses your components whilst allowing them to look great. It has numerous options for cooling, fashionable and functional filters over the various cooling entrances.
I love that the entire case is black, and the blue LED looks decent. It has enough room to clear my Xigmatek Dark Knight cooler, and then some, and I have had no real issues with cable lengths, just simply that there's nowhere to route cables effectively.
Another great attraction was the tool-less design. Whilst the locking mechanisms feel a bit cheap, they're easy to use, and get the job done, looking good in the process.
All in all, and all-star performer for the price.
  • Overall 4*
  • Ease of use 4*
cable management!!
Reviewed by kikassridec2. Review Posted 03/09/2011
a real qood quality strong case which can accomadate all size of mobos! as mentioned in the other review had to purchase a power supply pin adapter as it was not long enough to reach mobo but only cost me £2 ebay but biggest prob is cable management part from that looks the bizz and well happy with the size and looks of this case
  • Overall 4*
  • Ease of use 4*
PSU problems
Reviewed by David Jackson. Review Posted 08/04/2011
Case is fine but the location of the PSU means the power leads on standard PSU's do not reach the motherboard power conectors it would have been useful for the designer to have measured up first
  • Overall 3*
  • Ease of use 2*
  • Value for money 3*
Poor Quality Components
Reviewed by Rocky. Review Posted 19/03/2012
This case is basically OK, largely what it asys on the tin, except in one very important respect, the main 'on' switch has phisically disintegrated after less than 18 months use, i.e. past warranty, I'm having to replace it. I'm suprised that a well known brand can be undermined by a very poor component.
  • Overall 1*
  • Ease of use 4*
  • Value for money 2*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
