BT.com
Wishlist
CoolerMaster Elite 110 USB 3.0 Mini-ITX Case
CoolerMaster Elite 110 USB 3.0...
£39.62
£39.62
Add to wishlist
Delivery
Standard Due date unavailable
The Elite 110 is a mini cube compact case with support for full size standard desktop components. Other than the conventional mini-ITX case, the Elite 110 supports ample storage up to 3 HDDs / 4 SSDs and you can even install a radiator in the front for extreme cooling. It can accommodate the standard full size ATX PSU and the short dual slots graphic cards.
Cooler Master Elite 110 - ultra small form factor - mini ITX
System cabinet
Ultra small form factor
Midnight black
I/O Connectors
2 x USB 3.0 , 1 x microphone , 1 x audio line-out
Supported Motherboards
Mini-ITX
System Cabinet Features
Meshed front panel, blue LED
Specification Compliance
ATX / PS/2
26 cm x 28 cm x 20.8 cm
2.65 kg
Max Mainboard Size
Mini ITX
Mini-ITX
ATX / PS/2
Internal Bays Qty
3
Midnight black
Cooling System
Front: 120 mm fan x 1 / 1 x 140 mm fan supported , Side: 80 x 80 x 25 mm fan mount x 1
CPU Cooler Max Height
76 mm
Video Card Max Length
210 mm
Expansion Bays
3 (total) / 3 (free) x internal - 3.5" x 1/3H
Expansion Slots
2
2 x USB 3.0 , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
Max Supported Qty
1
26 cm
28 cm
20.8 cm
2.65 kg
Scroll to top
