BT.com
Wishlist
CoolerMaster Cosmos 2 - USB 3.0  XL-ATX Case
CoolerMaster Cosmos 2 - USB 3.0...
£345.31
£345.31
Add to wishlist
Delivery
Standard Due date unavailable
Inspired by luxurious supercars, the exterior of the Cosmos II melds aluminum, steel, and mesh into an elegant artistic piece. It maintains its trademark Cosmos profile and outlook with its reinforced aluminum rails while being further refined for today's advancements in air/water cooling, peripheral support, and styling. Large swinging aluminum side panels and sliding doors lend to its stylish and smooth movements to access ports, drives, and system hardware. With the Cosmos II, build as you wish as the options are endless.
Cooler Master Cosmos II - full tower - extended ATX
System cabinet
Full tower
Midnight black
I/O Connectors
4 x USB 2.0 , 2 x USB 3.0 , 1 x eSATA , 1 x microphone , 1 x headphones
Supported Motherboards
ATX, microATX, Extended ATX, SSI CEB, SSI EEB, XL-ATX
System Cabinet Features
Made of aluminium, meshed front panel
No power supply
Specification Compliance
EPS12V/ PS/2
34.4 cm x 70.4 cm x 66.4 cm
22 kg
2 years warranty
Full tower
Max Mainboard Size
Extended ATX
EPS12V/ PS/2
Internal Bays Qty
11
Front Accessible Bays Qty
5
Midnight black
Cooling System
Front: 200 mm fan x 1 / 700 rpm / 19 dBA / 1 x 120/140 mm fan supported , Top: 120 mm fan x 1 / 1200 rpm / 17 dBA , Rear: 140 mm fan x 1 / 1200 rpm / 19 dBA , Side: 120 mm fan mount x 2 , Top: 120 mm fan mount x 3 / 1 x 200 mm fan or 2 x 140 mm fan supported , Internal: 120 mm fan mount x 1 , Internal: 120 mm fan x 2 / 1200 rpm / 17 dBA
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 2 (total) / 2 (free) x front accessible - 3.5" x 1/3H , 11 (total) / 11 (free) x internal - 3.5" x 1/3H
Expansion Slots
11 x Expansion Slot
4 x USB 2.0 , 2 x USB 3.0 , 1 x eSATA , 1 x microphone - mini-jack , 1 x headphones - mini-jack
No power supply
Max Supported Qty
1
34.4 cm
70.4 cm
66.4 cm
22 kg
Scroll to top
