BT.com
Wishlist
CoolerMaster CM Storm Trigger Mechanical Gaming Keyboard - USB - black
Delivery
Standard Due date unavailable
The Trigger keyboard offers you the ability to press up to 6 keys simultaneously and utilize five programmable macro keys with profile management. These features give you the possibility to reduce transport and redeployment times by storing profiles and key assignments with 64KB of onboard memory. Next to this, the multi-media controls allow you to quickly adjust for example audio options to make working with the Trigger even easier.
A detachable wrist rest and non-slip rubber coating make sure you have maximal comfort and results while gaming, by providing proper support for wrists and reducing unwanted keyboard movements or slides.
The 18K gold plated ultra low latency USB connectors and the integrated two port USB 2.0 hub of the Trigger give you the option to connect other peripheral devices. A high-grade braided cable ensures that the keyboard and connected peripherals maintain a solid link to your PC or notebook.
For people who use their gaming keyboard in a dark environment, the Trigger also offers some nice back lighting options. You can either choose to have all the keys highlighted with Red LEDs, highlight only the WASD and arrow keys or have the LEDs in a breathing mode.
Something that is very important for the professional gamer is anti-ghosting. Normally when you are in-game you are used to pressing several keys simultaneously. That is why the CM Storm Trigger allows you to press 6 keys at once, without losing any of their functions.
Whether the weapon is chosen or that the weapon chooses you, the Trigger mechanical gaming keyboard is prepared with a full featured arsenal that incorporates a selection of extremely high durability CHERRY MX Black switches.
- High durability gold-plated Cherry switches rated for over 50 million key strokes
- Multi-media control keys for convenient sound control
- 5 macro keys with profile management
- 14K gold plated ultra low latency USB plugs
- Anti-ghosting 6 key rollover
- 64KB on-board memory for profile storage
- Storm tactics key for deactivation of Windows key
- 1000Hz driverless polling / 1ms response time
- Two port enhanced USB 2.0 hub
- Detachable wrist rest
- Braided cable for durability
- Non-slip rubber coating
Cooler Master CM Storm Trigger - keyboard - UK
Keyboard
Backlit
Red
USB
Layout
Hot Keys Qty
5
Hot Keys Function
Multimedia, programmable
Rubber coated housing, detachable wrist rest, 2-port USB hub, anti-ghosting, red LEDs, gold-plated connector, braided cable
16.2 cm x 47.5 cm x 2.5 cm
1.26 kg
Keyboard
Backlit
Red
USB
Input Device
Hot Keys Qty
5
Hot Keys Function
Layout
Keyboard Technology
Mechanical
16.2 cm
47.5 cm
2.5 cm
1.26 kg
2 x USB
Scroll to top
