A lightweight and multi-purpose gaming headset, CM Storm Sonuz is designed to be your single powerful solution for crisp and clear sound for any use. At home or on-the-go, the large high quality drivers in Sonuz will blow you away. It includes huge breathable on-ear padding that is both soft and comfortable while facilitating the delivery of deep full sounds far beyond your expectations. With its precise reproduction of audio, Sonuz is your gateway to hearing sounds as they are meant to be heard in your favorite games, movies, and music.
Features:
- Massive high quality 53mm drivers deliver amazing sound quality
- Innovative detachable 3.5mm microphone for use on either side of the headset
- Huge 97mm earpads provide great comfort
- Flexible headband for a perfect fit
- In-line remote with Volume control and microphone on/off button
