BT.com
Wishlist
CoolerMaster CM Storm Sonuz Gaming Headset
Delivery
Standard 3-5 working days
A lightweight and multi-purpose gaming headset, CM Storm Sonuz is designed to be your single powerful solution for crisp and clear sound for any use. At home or on-the-go, the large high quality drivers in Sonuz will blow you away. It includes huge breathable on-ear padding that is both soft and comfortable while facilitating the delivery of deep full sounds far beyond your expectations. With its precise reproduction of audio, Sonuz is your gateway to hearing sounds as they are meant to be heard in your favorite games, movies, and music.
Features:
- Massive high quality 53mm drivers deliver amazing sound quality
- Innovative detachable 3.5mm microphone for use on either side of the headset
- Huge 97mm earpads provide great comfort
- Flexible headband for a perfect fit
- In-line remote with Volume control and microphone on/off button
Cooler Master CM Storm Sonuz - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
Full size
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 10 - 20000 Hz - Sensitivity 98 dB
Impedance
45 Ohm
Microphone
Boom
Controls
Mute, volume
Headset
Recommended Use
Computer
Headphones
Circumaural
Dynamic
Wired
Available Microphone
Sound Output Mode
Stereo
Frequency Response
10 - 20000 Hz
Sensitivity
98 dB
Impedance
45 Ohm
Diaphragm
53 mm
In-Cord Volume Control
Microphone
Boom
Sensitivity
-47 dB
Frequency Response
100 - 10000 Hz
Signal-To-Noise Ratio
58 dB
Audio Input Details
Omni-directional
Remote Control
Controls
Mute, volume
Connector Type
Headphones ( mini-phone stereo 3.5 mm )
Cable
Plated Connector
Gold
Headset cable - 2 m
Scroll to top
