BT.com
Wishlist
CoolerMaster CM Storm QuickFire TK Mechanical Keyboard - BLUE MX Switches
Delivery
Standard Due date unavailable
You're a gamer. You know that a mechanical keyboard means the difference between winning and losing. The original QuickFire Rapid gaming keyboard was embraced by gamers worldwide because it made the difference. Now the QuickFire TK takes the QuickFire Rapid and put it on steroids! Choose between 3 different Cherry MX switches. Each keycap is UV coated to make it durable. There's full LED backlighting with 3 modes and 5 brightness levels. NKRO over USB means every single keystroke will be registered. An embedded steel plate give you maximum stability and durability. 7 easy-access multimedia shortcut keys save time. A complete numpad lets you get work done while not gaming. The slim and lightweight size gives you plenty of room for your mouse. Great for LAN parties.
Cooler Master CM Storm QuickFire TK - keyboard - Nordic
Keyboard
Backlit
Blue
USB
Layout
Nordic
Hot Keys Qty
7
Hot Keys Function
Volume, mute, brightness, play/pause, stop, previous track, next track
Individual key LED backlight, braided cable, removable USB cable, CHERRY MX Blue technology, removable keycaps
37.75 cm x 13.8 cm x 3.3 cm
544 g
2 years warranty
Keyboard
Backlit
Blue
USB
Input Device
Hot Keys Qty
7
Hot Keys Function
Layout
Nordic
Keyboard Technology
Mechanical
37.75 cm
13.8 cm
3.3 cm
544 g
Key removal tool
1 x USB cable - 1.8 m
Microsoft Windows Vista / XP / 7 / 8
Scroll to top
