BT.com
Wishlist
CoolerMaster 750W GM Series G750M 80 Plus Bronze Modular PSU
Delivery
Standard Due date unavailable
The intelligent 120 mm fan speed controller with honey combo mesh increases airflow for better heat dissipation. The custom 12 V to 3.3 V and 5 V module design offers notably higher efficiency and voltage stability than other designs. It offers high efficiency, improves the heat dissipation and reduces the unnecessary cables which results in much lower crosstalk, signal noise.
Cooler Master GM Series - power supply - 750 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31
80 PLUS Certification
80 PLUS Bronze
Europe
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 8 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
15 cm x 14 cm x 8.6 cm
ATX12V 2.31
PSU Form Factor
ATX
Europe
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+3.3V - 22 A , +5V - 22 A , +12V - 62 A , -12V - 0.3 A , +5VSB - 2.5 A
Modular Cable Management
80 PLUS Bronze
MTBF
100,000 hours
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, single 12V rail, DC-DC technology
UL, TUV, BSMI, CCC, FCC, EAC
15 cm
14 cm
8.6 cm
Scroll to top
