BT.com
Wishlist
Compaq Thunderbolt to Gigabit Ethernet plus USB 3.0 - Thunderbolt Adapter
Compaq Thunderbolt to Gigabit...
£32.13
25 in stock
£32.13
Add to wishlist
Delivery
Standard 3-5 working days
A must for any commuter, the notebook power adapters and chargers provide your notebook several charging options. Simply plug the adapter into the appropriate wall, auto or aircraft connection for power to the notebook without using up battery life. An additional AC adapter provides power for the notebook and charges the battery simultaneously. The auto power adapter provides all the charging convenience of the home or office by utilizing the cigarette lighter to charge the battery and power the notebook. The aircraft adapter powers the notebook and complies with industry regulations by not charging the battery while powering the notebook. The adapters provide you with the ability to power the notebook when away from the home or office.
HP - power adapter - 65 Watt
Power adapter - external
280 g
Output Voltage
18.5 V
Power Capacity
65 Watt
10.6 cm x 4.7 cm x 2.8 cm
1 year warranty
Input Voltage Range
AC 100 - 240 V
Frequency Required
47 - 63 Hz
Output Voltage
18.5 V
Power Capacity
65 Watt
1 year warranty
Service & Support Details
Limited warranty - 1 year
20 - 80%
10.6 cm
4.7 cm
2.8 cm
280 g
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* Do not buy it
Reviewed by Ray on 04/04/2005
This item does not come with the correct leads for use on an aircraft or car. The input voltage is incorrect for use in these circumstances. It is a regular Laptop adaptor without the mains lead. BT will provide customer support on this item.
Scroll to top
