BT.com
Wishlist
Clevertouch Plus 75" 4K 10-point touch with AG Glass
Delivery
Standard Due date unavailable
The powerful touchscreen technology is integrated into the screen enabling it to be dual touch, allowing multiple users. The Clevertouch range does not require drivers, calibration or set up. The crystal clear resolution and high brightness display means that images are clearly visible and unlike projection based interactive solutions, there is no shadowing.
The Clevertouch LED features a slimmer bezel, lower power consumption and a lighter weight, whilst still being as tough and durable as the Clevertouch LCD.
CleverTouch Plus 75" LED display
LED-backlit LCD flat panel display with touch-screen
Diagonal Class
75"
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
4 ports
Remote Control
Standard remote
Voltage
424 Watt
177.5 cm x 10.1 cm x 105.6 cm
88 kg
5 years warranty
424 Watt
Diagonal Class
75"
Combined with
Touch-screen
TV Tuner
No tuner
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
177.5 cm
10.1 cm
105.6 cm
88 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Image Contrast Ratio
1600:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Touchpoints Qty
10
Response Time
8 ms
Backlight Life
50,000 hour(s)
Stands & Mounts
Flat Panel Mount Interface
600 x 600 mm
Media Player
USB Port
USB Ports Qty
4
PC Configuration
ARM Cortex-A9 Dual-Core / 1.5 GB RAM / 8 GB Flash
Operating System
Android OS 4.2.1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connect & Share
Wireless HD Ready (WHDI)
Connector Type
Composite video input , 3 x VGA input , 3 x HDMI input , 3 x audio line-in , Audio line-in , VGA output , Headphones , Digital audio output (coaxial) , 3 x USB 2.0 , USB 3.0 , Serial , LAN
Pen
USB cable - 5 m , VGA cable - 5 m , Audio cable - 5 m
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Limited warranty - 5 days
Width (Shipping)
194 cm
Depth (Shipping)
27.5 cm
Height (Shipping)
124 cm
Weight (Shipping)
104 kg
Scroll to top
