BT.com
Wishlist
Clevertouch Plus 75" 1080p 10point Touch HDMI VGA LED Interactive
Delivery
Standard Due date unavailable
The powerful touchscreen technology is integrated into the screen enabling it to be dual touch, allowing multiple users. The Clevertouch range does not require drivers, calibration or set up. The crystal clear resolution and high brightness display means that images are clearly visible and unlike projection based interactive solutions, there is no shadowing.
The Clevertouch LED features a slimmer bezel, lower power consumption and a lighter weight, whilst still being as tough and durable as the Clevertouch LCD.
CleverTouch Plus 75" LED display
LED-backlit LCD flat panel display with built-in PC and touch-screen
418 Watt
Diagonal Class
75"
177.5 cm x 10.1 cm x 105.6 cm
88 kg
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
120Hz Refresh Rate
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB Port
Yes , 5 ports
Remote Control
Standard remote
AC 120/230 V ( 50/60 Hz )
5 years warranty
418 Watt
Diagonal Class
75"
Combined with
Built-in PC and touch-screen
TV Tuner
No tuner
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
177.5 cm
10.1 cm
105.6 cm
88 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
120Hz Refresh Rate
LED backlight
Coating
Anti-glare
Image Contrast Ratio
5000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Touchpoints Qty
10
Response Time
6 ms
Backlight Life
50,000 hour(s)
Dual-Core processor
Stands & Mounts
Flat Panel Mount Interface
600 x 600 mm
Media Player
USB Port
Yes , 5 ports
PC Configuration
ARM Cortex-A9 Dual-Core / 1.5 GB RAM / 8 GB Flash
Operating System
Android OS 4.2.1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
Composite video input , 3 x VGA input , 3 x HDMI input , 3 x audio line-in , Audio line-in , VGA output , Headphones , Digital audio output (coaxial) , 4 x USB 2.0 , USB 3.0 , Serial , LAN
2 pens
USB cable - 5 m , VGA cable - 5 m , Audio cable - 5 m
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Limited warranty - 5 days
Width (Shipping)
194 cm
Depth (Shipping)
28 cm
Height (Shipping)
124 cm
Weight (Shipping)
104 kg
Scroll to top
