BT.com
Wishlist
Citizen CL-S521 Monochrome Direct Thermal Label Printer
Citizen CL-S521 Monochrome Direct...
£334.41
18 in stock
£334.41
Add to wishlist
Delivery
Standard 1-3 working days
If you're looking for a rugged, precise barcode/label printer that delivers maximum performance, look no further. The CL-S521 direct thermal printer combines robust printing with superior price performance, ease of use and precision engineering. You'll love Citizen's unique metal Hi-Lift print mechanism, allowing for quick media loading while an adjustable sensor easily handles a variety of media and label configurations including standard and pediatric medical wristbands. Also, the powerful on-board 32 bit RISC processor delivers exceptional throughput and fast first label out.
Citizen CL-S521 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
3.6 kg
Max Media Size
Roll (11.8 cm)
Print Speed
Up to 152 mm/sec - B/W
Max Resolution (B&W)
203 dpi
USB, serial
RAM Installed (Max)
16 MB SDRAM
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL
Barcodes
Code 93, UCC/EAN-128, NW-7, QR code, MaxiCode, Telepen, HIBCC, EAN/JAN-8 , EAN/JAN-13 , UPC-A, UPC-E, Codabar, Code 128, Code 3 of 9, Interleaved 2 of 5, PDF417, Data Matrix, FIM, Plessey, ZIP
Media Type
Labels, continuous forms, fanfold paper, tickets
Printer Features
Hi-Lift metal mechanism
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
2 years warranty
23.1 cm x 28.9 cm x 18.6 cm
Printer Type
Enclosure Colour
Dark grey
Printer
Print Speed
Wired
USB, serial
203 dpi
Language Simulation
ZPL
Barcodes
Printer Features
RAM
RAM Installed (Max)
16 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (11.8 cm)
Media Sizes
Roll (11.8 cm)
Max Printing Width
104 mm
Max Printing Length
812 mm
Media Thickness Range
0.0635 mm - 0.254 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25 mm
Media Feeders
1 x manual - 1 roll - Roll (11.8 cm)
1 x RS-232 - 25 pin D-Sub (DB-25) , 1 x USB - 4 PIN USB Type B
FCC Class A certified, UL, cUL, CCC, RoHS
Power supply - internal
Software Included
Drivers & Utilities
2 years warranty
Service & Support Details
23.1 cm
28.9 cm
18.6 cm
3.6 kg
Scroll to top
