BT.com
Wishlist
Cisco Wired Microphone Kit (Pack of 2) for Unified IP Conference Phone 8831
Cisco Wired Microphone Kit (Pack of...
£227.74
45 in stock
£227.74
Add to wishlist
Delivery
Standard 3-5 working days
The Cisco Unified IP Conference Phone 8831 enhances people-centric communications, combining superior high-definition (HD) audio performance and 360-degree coverage for all sizes of conference rooms and executive offices. It provides an audiophile sound experience with a full-duplex two-way wideband (G.722) audio hands-free speaker.
The IP Conference Phone 8831 is a simple, scalable solution that meets the challenges of the most diverse rooms. It provides flexible deployment options and expansion by using extension microphones that can be wired or wireless (Digital Equipment Cordless Telephone) with a daisy-chain configuration of two units.
The IP Conference Phone 8831 has an industrial design with enhanced ergonomics that puts the user first. It offers a detached control panel so that the display may be easily viewed without having to move the entire unit. It also provides easy view of device mute status from all sides. Supported on Cisco Unified Communications Manager and Business Edition systems, the IP Conference Phone 8831 delivers a more productive, acoustically pleasing, and secure communications experience across sites and participants.
Cisco Wired Microphone Kit - microphone
Microphone
Packaged Quantity
2 (specifications are for single item)
Recommended Use
Conference
Microphone
External
Packaged Quantity
Microphone
6.35 cm
1.27 cm
8.89 cm
66.8 g
Recommended Use
Conference
Microphone
Wired
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Item has been opened and is in excellent condition.
Ref: B1X0 032417
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£33.91
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
