BT.com
Wishlist
Cisco VG204XM Analog Voice Gateway
£775.23
7 in stock
£775.23
Add to wishlist
Delivery
Standard 3-5 working days
The Cisco VG204XM Analog Voice Gateways allow you to use your IP telephony solution with traditional analog devices while taking advantage of the productivity afforded by IP infrastructure.
The Cisco VG204XM is ideal for analog phone deployments ranging from centralized to sparsely concentrated or distributed topologies. These analog voice gateways provide a high level of availability at locations with MGCP fallback, with ease of manageability using Cisco IOS software monitoring features. They offer many supplementary analog calling features depending on the call control and signaling type used.
Cisco VG204XM Analog Voice Gateway - VoIP phone adapter
VoIP phone adapter
External
RAM
256 MB
Flash Memory
128 MB
Ethernet, Fast Ethernet
VoIP Protocols
MGCP, SCCP, SIP, H.323 v4, RTP, SRTP
Telephony Interfaces
4 phone (FXS)
22.38 cm x 20.65 cm x 4.52 cm
1.351 kg
VoIP phone adapter
22.38 cm
20.65 cm
4.52 cm
1.351 kg
Processor / Memory / Storage
RAM
256 MB DDR2 SDRAM
Flash Memory
128 MB
External
Wired
Network / Transport Protocol
DHCP, DNS
Routing Protocol
HSRP
Remote Management Protocol
Telnet, SNMP 3, HTTP, TFTP, CLI
Wall mountable, RADIUS support
Authentication Method
RADIUS, TACACS+
IP Telephony
VoIP Protocols
Voice Codecs
G.711, G.729a, T.38
4 phone (FXS)
IP Telephony Features
Caller ID, call waiting, automatic fax/modem detection and pass-through, call hold, call transfer
2 x 100Base-TX - RJ-45 , 1 x management - RJ-45 , 1 x management , 4 x modem - RJ-11
MTBF
200,000 hours
CISPR 22 Class B, CISPR 24, EN 61000-3-2, IEC 60950, EN 61000-3-3, EN55024, UL 60950, EN50082-1, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN300-386, EN 60950-1, AS/NZS 60950, CAN/CSA C22.2 No. 60950, VCCI Class B
External power adapter
30 Watt
10 - 85% (non-condensing)
Accessories
£4.95
£3.84
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.34
£52.93
Scroll to top
