BT.com
Wishlist
Cisco VG202XM Analog Voice Gateway VoIP Phone Adapter
Cisco VG202XM Analog Voice Gateway...
£498.90
£498.90
Add to wishlist
Delivery
Standard Due date unavailable
The Cisco VG202XM voice gateways are analog voice gateways for the service provider, commercial, and enterprise unified communication markets. These voice gateways provide voice connectivity to devices such as analog phones, fax machines, and modems.
The Cisco VG202XM voice gateways provide support for 2-FXS ports and parity with Cisco IOS fax/modem, security, and Session Initiation Protocol (SIP) features. These voice gateways can be configured with Cisco Unified Communications Manager Express (CUCME) or Cisco Unified Communications Manager (CUCM).
Cisco VG202XM Analog Voice Gateway - VoIP phone adapter
VoIP phone adapter
External
RAM
256 MB
Flash Memory
128 MB
Ethernet, Fast Ethernet
VoIP Protocols
MGCP, SCCP, SIP, H.323 v4, RTP, SRTP
Telephony Interfaces
2 phone (FXS)
AC 120/230 V ( 50/60 Hz )
22.38 cm x 20.65 cm x 4.52 cm
1.351 kg
VoIP phone adapter
22.38 cm
20.65 cm
4.52 cm
1.351 kg
Processor / Memory / Storage
RAM
256 MB DDR2 SDRAM
Flash Memory
128 MB
External
Wired
Network / Transport Protocol
DHCP, DNS
Routing Protocol
HSRP
Remote Management Protocol
Telnet, SNMP 3, HTTP, TFTP, CLI
Wall mountable, RADIUS support
Authentication Method
RADIUS, TACACS+
IP Telephony
VoIP Protocols
Voice Codecs
G.711, G.729a, T.38
2 phone (FXS)
IP Telephony Features
Caller ID, call waiting, automatic fax/modem detection and pass-through, call hold, call transfer
2 x 100Base-TX - RJ-45 , 1 x management - RJ-45 , 1 x management , 2 x modem - RJ-11
MTBF
200,000 hours
CISPR 22 Class B, CISPR 24, EN 61000-3-2, IEC 60950, EN 61000-3-3, EN55024, UL 60950, EN50082-1, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN300-386, EN 60950-1, AS/NZS 60950, CAN/CSA C22.2 No. 60950, VCCI Class B
External power adapter
30 Watt
10 - 85% (non-condensing)
Accessories
£4.95
£3.84
£11.78
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.42
£52.93
Scroll to top
