BT.com
Wishlist
Cisco Smart Plus SF220-48P Switch Managed 48 x 10/100 (PoE)
Cisco Smart Plus SF220-48P Switch...
£657.94
£657.94
Add to wishlist
Delivery
Standard Due date unavailable
Cisco Small Business 220 series smart plus switches bridge the gap between managed and smart switches to offer customers the best of both worlds. Combining powerful performance with reliability, they provide the higher levels of security, management, and scalability you expect from managed switches, affordably priced like smart switches.
Cisco Small Business Smart Plus SF220-48P - switch - 48 ports - Managed - desktop, rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Fast Ethernet
Ports
48 x 10/100 (PoE) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
375 W
Performance
Forwarding performance (64-byte packet size): 10.12 Mpps , Switching capacity: 13.6 Gbps
MAC Address Table Size
8192 entries
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Flow control, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), RADIUS support, MLD snooping, reset button, LLDP support, Link Aggregation Control Protocol (LACP)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
AC 120/230 V ( 50/60 Hz )
44 cm x 35 cm x 4.4 cm
5.12 kg
United Kingdom
Bundled Services
Enclosure Type
Subtype
Fast Ethernet
Ports
PoE
PoE Budget
375 W
Performance
8192 entries
Authentication Method
RADIUS, TACACS+
RAM
128 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, system, PoE, link/activity
48 x 100Base-TX - RJ-45 - PoE - 15.4 W , 2 x 1000Base-T - RJ-45 , 2 x 1000Base-X - SFP
Internal power supply
MTBF
210,753 hours
C-Tick, UL 60950, FCC CFR47 Part 15, CSA 22.2
United Kingdom
44 cm
35 cm
4.4 cm
5.12 kg
Limited warranty - replacement - lifetime , Technical support - web support - 1 year , Technical support - phone consulting - 1 year , Limited warranty - power supply and fans - 1 year , Limited warranty - software - 90 days
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Scroll to top
