BT.com
Wishlist
Cisco Small Business Switch 16 Ports POE Gigabit
Cisco Small Business Switch 16...
£161.36
£161.36
Add to wishlist
Delivery
Standard Due date unavailable
Easily build a highly reliable network to connect your computers, printers, copiers, and other office equipment. If your business is like most small companies, you do not have an IT staff to set up your network for you. Now you can have a high-performance, business-class office network that just works, right out of the box, with the Cisco 110 series Unmanaged Switches. Users, workgroups, labs, departments, or growing offices can now deliver large amounts of multimedia, image, and video information across the network in almost no time.
Cisco 110 series Unmanaged Switches deliver basic network connectivity and reliability for small businesses that is easy on the budget and without all the complexity. These switches provide all of the features, expandability, and investment protection you expect from Cisco, with no installation software and nothing to configure. Just plug it in, connect your computers and other business equipment, and get to work.
Cisco 110 series Unmanaged Switches, part of the Cisco Small Business networking solutions, are a line of unmanaged switches that provide wire-speed Fast Ethernet and Gigabit Ethernet connectivity to connect your small business office. They use less power and provide the robust, reliable connectivity your business demands, as well as support for advanced features such as quality of service (QoS), loop detection, and cable diagnostics, all in a switch that you can set up yourself in minutes. A business-class, affordable network solution, Cisco 110 series switches bring the proven reliability and investment protection of Cisco networking solutions to your small business.
Cisco Small Business SG110-16HP - switch - 16 ports - unmanaged
Switch - 16 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 8 x 10/100/1000 (PoE)
Power Over Ethernet (PoE)
PoE
PoE Budget
64 W
Performance
Switching capacity: 32 Gbps , Forwarding performance (64-byte packet size): 23.8 Mpps
QoS hardware queues: 4
Jumbo Frame Support
9216 bytes
Quality of Service (QoS), Energy Efficient Ethernet, security lock slot (cable lock sold separately), cable test
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
27.94 cm x 17 cm x 4.45 cm
1.43 kg
Europe
Bundled Services
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
64 W
Performance
Jumbo Frame Support
9216 bytes
RAM
128 MB
Flash Memory
128 MB
Status Indicators
Power, system, PoE, link/activity, diagnostic, loop
8 x 1000Base-T - RJ-45 , 8 x 1000Base-T - RJ-45 - PoE
Internal power supply
UL 60950, FCC CFR47 Part 15, CSA 22.2
Europe
27.94 cm
17 cm
4.45 cm
1.43 kg
Limited warranty - lifetime
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Scroll to top
