BT.com
Wishlist
Cisco Small Business SG250-10P Switch Smart 8 x 10/100/1000
Cisco Small Business SG250-10P...
£337.60
Hurry, only 2 left in stock!
£337.60
Add to wishlist
Delivery
Standard 1-3 working days
Cisco Small Business SG250-10P - Switch - smart - 8 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP - desktop - PoE+
Cisco Small Business SG250-10P - switch - 10 ports - smart - desktop
Switch - 10 ports - smart
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
Power Over Ethernet (PoE)
PoE+
PoE Budget
62 W
Performance
Switching capacity: 20 Gbps , Forwarding performance (64-byte packet size): 14.88 Mpps
Active VLANs: 256
MAC Address Table Size
8K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMP, static IPv4 routing
Remote Management Protocol
SNMP, RMON, HTTP, HTTPS, TFTP, SCP
DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), MLD snooping, reset button, LLDP support, 12MB packet buffer, Storm Control, SmartPort technology, Cisco Discovery Protocol
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
AC 120/230 V ( 50 - 60 Hz )
28 cm x 17 cm x 4.4 cm
1.2 kg
United Kingdom
Bundled Services
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
62 W
Performance
Active VLANs: 256
8K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
Encryption Algorithm
MD5, SSL
Authentication Method
RADIUS
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Link activity
8 x 1000Base-T - RJ-45 - PoE+ - 62 W , 2 x 1000Base-T - RJ-45/SFP - PoE - 60 W , 1 x USB - management
External power adapter
1 x power cable
MTBF
205,647 hours
UL 60950, CSA 22.2, FCC CFR47 Part 15 A
United Kingdom
28 cm
17 cm
4.4 cm
1.2 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Scroll to top
