BT.com
Wishlist
Cisco Small Business SF302-08PP Switch L3 Managed
Cisco Small Business SF302-08PP...
£208.86
More than 50 in stock
£208.86
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco 300 series, part of the Cisco Small Business line of network solutions is a portfolio of affordable managed switches that provides a reliable foundation for your business network. These switches deliver the features you need to improve the availability of your critical business applications, protect your sensitive information, and optimize your network bandwidth to deliver information and applications more effectively. Easy to set up and use, the Cisco 300 series provides the ideal combination of affordability and capabilities for small businesses, and helps you create a more efficient, better-connected workforce.
The Cisco 300 series is broad portfolio of fixed-configuration managed Ethernet switches. However, unlike other small business switching solutions that provide managed network capabilities only in the costliest models, all Cisco 300 series switches support the advanced security management capabilities and network features you need to support business-class data, voice, security, and wireless technologies. At the same time, these switches are simple to deploy and configure, allowing you to take advantage of the managed network services your business needs.
Cisco Small Business SF302-08PP - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - L3 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
62 W
Performance
Switching capacity: 5.6 Gbps , Forwarding performance (64-byte packet size): 4.17 Mpps
ACL rules: up to 512
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2, CLI
Layer 3 switching, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, fanless, Energy Efficient Ethernet, 8MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
27.94 cm x 17 cm x 4.45 cm
1.18 kg
Chinese (simplified), English, German, French, Italian, Spanish, Japanese / United Kingdom
Bundled Services
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE+
PoE Budget
62 W
Performance
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Static IPv4 routing
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Port transmission speed, system, link/activity
8 x 100Base-TX - RJ-45 - PoE+ , 1 x console - DB-9 - management , 2 x 1000Base-T - RJ-45 , 2 x 1000Base-X - SFP
External power adapter
1 x serial cable
Rack Mounting Kit
Included
MTBF
899,905 hour(s)
UL 60950, CSA 22.2 No. 60950, FCC Part 15 A
27.94 cm
17 cm
4.45 cm
1.18 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.82
£11.94
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.61
£54.13
Scroll to top
