BT.com
Wishlist
Cisco Small Business RV325 Desktop Router
Cisco Small Business RV325 Desktop...
£212.14
43 in stock
£212.14
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco RV325 dual gigabit WAN VPN router is no exception. Featuring intuitive user interfaces, it will have you up and running in mere minutes. The capable router provides reliable, highly secure connectivity for you and your employees and work so well that you won't even know the router is there.
Cisco Small Business RV325 - router - desktop
Router - 14-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Performance
NAT throughput: 900 Mbps , VPN throughput (IPSec): 100 Mbps , VPN throughput (SSL): 20 Mbps
Virtual interfaces (VLANs): 17 , PPTP VPN tunnels: 10 , SSL VPN tunnels: 10 , VPN tunnels (site-to-site): 25 , IPSec VPN tunnels: 25 , Concurrent connections: 40000 , ACL rules: 50
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, Bonjour, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing, RIPng
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
DMZ port, NAT support, hardware encryption, VPN support, PAT support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, E-mail alert, IPv6 support, firmware upgradable, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), DHCP server, reset button, bandwidth control, DHCP relay, DNS relay, DHCP client
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q
24.3 cm x 17.7 cm x 4.5 cm
Taiwan, Thailand, Singapore, India, Europe
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, FCC Class B certified, UL, BSMI, cUL, CB, CCC, ANATEL, KC
Status Indicators
Port transmission speed, power, WAN, DMZ, link/activity, DMZ/Internet, diagnostic, USB, VPN
LAN: 14 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / DMZ: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
External power adapter
1 x network cable
Software Included
Drivers & Utilities
24.3 cm
17.7 cm
4.5 cm
Limited warranty - lifetime
10 - 85% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.80
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.20
£14.67
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£27.14
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.52
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£37.98
Scroll to top
