BT.com
Wishlist
Cisco Small Business RV130W Wireless Router 802.11b/g/n - Desktop/Wall-Mountable
Cisco Small Business RV130W...
£117.45
More than 50 in stock
£117.45
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco RV130W Wireless-N Multifunction VPN Router is an easy-to-use, flexible, high-performance device well suited for small businesses. It delivers highly secure, broadband, wired and wireless connectivity to small offices and remote employees. It can also be used either as a standalone wireless router, access point, bridge or repeater for flexible deployments, offering investment protection as your business needs evolve.
Cisco Small Business RV130W - wireless router - 802.11b/g/n - desktop, wall-mountable
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Performance
NAT throughput: 800 Mbps , VPN throughput (IPSec): 50 Mbps
Concurrent sessions: 12000 , Gateway to gateway IPSec VPN Tunnels: 10 , Client to gateway IPSec VPN tunnels: 10 , PPTP VPN tunnels: 10 , Wireless clients: up to 64
Jumbo Frame Support
9000 bytes
Network / Transport Protocol
PPTP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP, Bonjour, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing, static IPv6 routing, RIPng
Remote Management Protocol
SNMP 3, HTTP, HTTPS
DMZ port, NAT support, hardware encryption, PAT support, VLAN support, repeating mode, Syslog support, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, Access Point operational mode, firmware upgradable, Rapid Spanning Tree Protocol (RSTP) support, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough, DHCP server, Multiple SSID support, DNS proxy, HTTP proxy, port forwarding, wireless bridge mode, reset button, DHCP relay, Stateful Packet Inspection Firewall (SPIF), 3G/4G USB Dongle Support, SNMP trap, DHCP client, NTP time synchronisation, Class of Service (CoS), IGMP proxy, security lock slot (cable lock sold separately), DiffServ Code Point (DSCP) support, PPTP passthrough, L2TP passthrough
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, UPnP
Indonesia, Vietnam, Hong Kong, Thailand, Malaysia, Singapore, India, Philippines, Korea, Russia, Europe
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz
Selectable Channels Qty
13
Performance
Jumbo Frame Support
9000 bytes
Routing Protocol
SNMP 3, HTTP, HTTPS
Encryption Algorithm
DES, Triple DES, MD5, AES, 128-bit WEP, 64-bit WEP, SHA-1, TKIP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, UPnP, FCC Class B certified, IC
Status Indicators
Power, WAN, LAN, wireless, USB, VPN
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 1 x 4 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
2
Gain Level
2 dBi
External power adapter
1 x network cable
OS Provided
Linux
Software Included
Drivers & Utilities
Limited warranty - lifetime
10 - 85% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.80
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.53
£15.73
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.21
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.64
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£40.15
£42.31
Scroll to top
