BT.com
Wishlist
Cisco SG500X-48MP 48-port Gig + 4 10-Gig Max PoE+ Switch
Cisco SG500X-48MP 48-port Gig + 4...
£2,466.37
£2,466.37
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco 500 series stackable managed switch provides the advanced capabilities you need to support a more demanding network environment, at an affordable price. It is designed to protect your technology investment as your business grows. Unlike switches that claim to be stackable but have elements which are administered and troubleshot separately, the Cisco 500 series provides true stacking capability, allowing you to configure, manage, and troubleshoot multiple physical switches as a single device and more easily expand your network. The Cisco 500 series switch is fanless making it one of the industry's first in stackable switches, thereby delivering increased reliability, power efficiency, and minimizing noise.
Cisco Small Business SG500X-48MP - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
740 W
Performance
Switching capacity: 176 Gbps , Forwarding performance (64-byte packet size): 130.95 Mpps
ACL rules: up to 3072
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
RIP-2, VRRP, static IPv4 routing, static IPv6 routing, CIDR
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Flow control, Layer 2 switching, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), reset button, STP Root Guard, Uni-Directional Link Detection (UDLD), DHCP relay, IP-MAC binding, Energy Efficient Ethernet, Class of Service (CoS), Generic Attribute Registration Protocol (GARP), GARP VLAN Registration Protocol (GVRP), DiffServ Code Point (DSCP) support, 4 fans
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 35 cm x 4.4 cm
5.43 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
740 W
Performance
16K entries
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
256 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, system, PoE, link/activity
48 x 1000Base-T - RJ-45 - PoE+ - 30 W , 4 x 10GBase-X - SFP+ , 2 x - SFP , 1 x console - DB-9 - management
Internal power supply
1 x serial cable
Rack Mounting Kit
Included
MTBF
307,978 hours
UL 60950, FCC Part 15 A, CSA 22.2
44 cm
35 cm
4.4 cm
5.43 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£5.16
£3.90
£12.61
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£57.07
Scroll to top
