BT.com
Wishlist
Cisco SG500X-24MPP 24-port Gig + 4 10-Gig Max PoE+ Switch
Cisco SG500X-24MPP 24-port Gig + 4...
£1,589.82
£1,589.82
Add to wishlist
Delivery
Standard Due date unavailable
The Cisco 500 series offers the advanced capabilities you need to support a more demanding network environment, at an affordable price. It provides a solid foundation for your current business applications, as well as those you are planning for the future.
Cisco 500 series switch provides the advanced feature set that growing businesses require, and that high-bandwidth applications and technologies demand. This switch can improve the availability of your critical applications, protect your business information, and optimize your network bandwidth to more effectively deliver information and support applications.
The switch offers a higher level of features and reliability you need to expand your business with confidence. Combining advanced network management, security, and availability features in an affordable, easy-to-manage solution, this switch provides the ideal technology foundation for your business.
Cisco Small Business SG500X-24MPP - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
740 W
Performance
Switching capacity: 128 Gbps , Forwarding performance (64-byte packet size): 95.24 Mpps
ACL rules: up to 3072
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
RIP-2, VRRP, static IPv4 routing, static IPv6 routing, CIDR
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Flow control, Layer 2 switching, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), reset button, STP Root Guard, Uni-Directional Link Detection (UDLD), DHCP relay, IP-MAC binding, Energy Efficient Ethernet, 12MB packet buffer, Class of Service (CoS), Generic Attribute Registration Protocol (GARP), GARP VLAN Registration Protocol (GVRP), DiffServ Code Point (DSCP) support, 3 fans
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 35 cm x 4.4 cm
4.61 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
740 W
Performance
16K entries
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
256 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, system, PoE, link/activity
24 x 1000Base-T - RJ-45 - PoE+ - 30 W , 4 x 10GBase-X - SFP+ , 2 x - SFP , 1 x console - DB-9 - management
Internal power supply
1 x serial cable
Rack Mounting Kit
Included
MTBF
428,088 hours
UL 60950, FCC Part 15 A, CSA 22.2
44 cm
35 cm
4.4 cm
4.61 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.74
£11.19
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.02
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.63
£50.74
Scroll to top
