BT.com
Wishlist
Cisco SG300-10PP 10-port Gigabit PoE+ Managed Switch
Cisco SG300-10PP 10-port Gigabit...
£251.53
29 in stock
£251.53
Add to wishlist
Delivery
Standard 1-3 working days
Cisco 300 series switches deliver the ideal combination of price, performance, and capabilities in a solution designed specifically for small businesses. This broad portfolio of affordable managed switches provides a powerful foundation to support your business network.
Cisco Small Business SG300-10PP - switch - 10 ports - Managed - rack-mountable
Switch - 10 ports - L3 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
62 W
Performance
Switching capacity: 20 Gbps , Forwarding performance (64-byte packet size): 14.88 Mpps
ACL rules: up to 512
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Layer 3 switching, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, fanless, Energy Efficient Ethernet, 8MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
27.94 cm x 17 cm x 4.45 cm
1.24 kg
Chinese (simplified), English, German, French, Italian, Spanish, Japanese / United Kingdom
Bundled Services
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
62 W
Performance
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Static IPv4 routing
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Link activity, port transmission speed, system
8 x 1000Base-T - RJ-45 - PoE+ , 2 x 1000Base-T - RJ-45 , 1 x console - DB-9 - management , 2 x 1000Base-X - SFP
External power adapter
1 x serial cable
Rack Mounting Kit
Included
MTBF
945,042 hour(s)
UL 60950, CSA 22.2 No. 60950, FCC Part 15 A
27.94 cm
17 cm
4.45 cm
1.24 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Other bundles
£251.53
Save on TP Link Smart Plug
Save £2.00
£275.50
Scroll to top
