BT.com
Wishlist
Cisco SG200-08 8-port Gigabit Smart Switch
Cisco SG200-08 8-port Gigabit Smart...
£75.27
29 in stock
£75.27
Add to wishlist
Delivery
Standard 3-5 working days
Cisco 200 series switch is a series of affordable smart switch that combine powerful network performance and reliability with the essential network management features you need for a solid business network. This expandable fast Gigabit Ethernet switch provides basic management, security, and quality-of-service (QoS) features beyond those of an unmanaged or consumer-grade switch, at a lower cost than managed switch. And with an easy-to-use web user interface, Cisco discovery protocol and Cisco Smartports you can deploy and configure a rock-solid business network in minutes.
Cisco Small Business Smart SG200-08 - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Switching capacity: 13.6 Gbps , Forwarding performance (64-byte packet size): 11.9 Mpps
MAC Address Table Size
8000 entries
Jumbo Frame Support
Remote Management Protocol
RMON, HTTP, TFTP
Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, fanless
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
11.3 cm x 13 cm x 2.7 cm
0.75 kg
United Kingdom
Bundled Services
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
8000 entries
Jumbo Frame Support
RMON, HTTP, TFTP
Encryption Algorithm
MD5
Authentication Method
RADIUS
RAM
32 MB
Flash Memory
8 MB
Status Indicators
Link activity, port transmission speed, system
8 x 1000Base-T - RJ-45
Internal power supply
Mounting Kit
Included
MTBF
71,834 hours
UL 60950, FCC Part 15 A, CSA 22.2
United Kingdom
11.3 cm
13 cm
2.7 cm
0.75 kg
Limited warranty - lifetime , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Scroll to top
