BT.com
Wishlist
Cisco SG110-24 24-Port Gigabit Switch
Cisco SG110-24 24-Port Gigabit...
£132.48
27 in stock
£132.48
Add to wishlist
Delivery
Standard 1-3 working days
Easily build a highly reliable network to connect your computers, printers, copiers, and other office equipment. If your business is like most small companies, you do not have an IT staff to set up your network for you. You can have a high-performance, business-class office network that just works, right out of the box, with the Cisco 110 series unmanaged switches. Users, workgroups, labs, departments, or growing offices can deliver large amounts of multimedia, image, and video information across the network in almost no time. Cisco 110 series unmanaged switches deliver basic network connectivity and reliability for small businesses that is easy on the budget and without all the complexity. These switches provide all of the features, expandability, and investment protection you expect from Cisco, with no installation software and nothing to configure. Just plug it in, connect your computers and other business equipment, and get to work.
Cisco Small Business SG110-24 - switch - 24 ports - unmanaged - rack-mountable
Switch - 24 ports - unmanaged
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x combo Gigabit SFP
Performance
Switching capacity: 48 Gbps , Forwarding performance (64-byte packet size): 35.7 Mpps
QoS hardware queues: 4
Jumbo Frame Support
9216 bytes
Weighted Round Robin (WRR) queuing, Quality of Service (QoS), fanless, Energy Efficient Ethernet, security lock slot (cable lock sold separately), cable test
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
44.06 cm x 20.282 cm x 4.432 cm
1.63 kg
United Kingdom
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Jumbo Frame Support
9216 bytes
RAM
128 MB
Flash Memory
128 MB
Status Indicators
Power, 100M device connected, system, link/activity, loop
24 x 1000Base-T - RJ-45 , 2 x 1000Base-X - SFP
Internal power supply
UL 60950, FCC CFR47 Part 15, CSA 22.2
United Kingdom
44.06 cm
20.282 cm
4.432 cm
1.63 kg
Limited warranty - lifetime
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Scroll to top
