BT.com
Wishlist
Cisco SFP (mini-GBIC) Transceiver Module
Cisco SFP (mini-GBIC) Transceiver...
£272.37
24 in stock
£272.37
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco industry-standard 1000BASE-T Small Form-factor Pluggable (SFP) gigabit interface converter (GBIC) is a hot-swappable input/output device that plugs into a Gigabit Ethernet port or slot, linking the port with the network. The Cisco SFP provides full-duplex Gigabit Ethernet connectivity to high-end workstations and between wiring closets over existing copper network infrastructure.
Cisco - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
GigE
1.4 cm x 7.1 cm x 1.4 cm
90 days warranty
P/N: CWDM-SFP-1490, CWDM-SFP-1490=, CWDM-SFP-1510, CWDM-SFP-1510=, CWDM-SFP-1530, CWDM-SFP-1550=, CWDM-SFP-1570, CWDM-SFP-1570=, CWDM-SFP-1590, CWDM-SFP-1590=, CWDM-SFP-1610, CWDM-SFP-1610=, GLC-GE-100FX, GLC-GE-100FX=, SFP-GE-L, SFP-GE-L=, SFP-GE-S, SFP-GE-S=, SFP-GE-T=, SFP-GE-Z, SFP-GE-Z=
Plug-in module
Wired
Cabling Type
1000Base-T
GigE
Data Transfer Rate
1 Gbps
1 x Ethernet 1000Base-T - RJ-45
Compatible Slots
1 x SFP (mini-GBIC)
NEBS level 3
1.4 cm
7.1 cm
1.4 cm
Limited warranty - 90 days
70 °C
P/N: CISCO10720-AC-A, CISCO10720-AC-A=, CISCO10720-DC-A, CISCO10720-DC-A=, CWDM-SFP-1470=, CWDM-SFP-1490, CWDM-SFP-1490=, CWDM-SFP-1510, CWDM-SFP-1510=, CWDM-SFP-1530, CWDM-SFP-1550=, CWDM-SFP-1570, CWDM-SFP-1570=, CWDM-SFP-1590, CWDM-SFP-1590=, CWDM-SFP-1610, CWDM-SFP-1610=, GLC-GE-100FX, GLC-GE-100FX=, SFP-GE-L, SFP-GE-L=, SFP-GE-S, SFP-GE-S=, SFP-GE-T=, SFP-GE-Z, SFP-GE-Z=
Scroll to top
