BT.com
Wishlist
Cisco SFP (mini-GBIC) Transceiver Module
Cisco SFP (mini-GBIC) Transceiver...
Clearance
£42.63
Clearance
Last Few Remaining
Price Drop
Price Drop
£42.63
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The industry-standard Cisco Small Form-Factor Pluggable (SFP) Gigabit Interface Converter links your switches and routers to the network. The hot-swappable input/output device plugs into a Gigabit Ethernet port or slot.
Cisco - SFP (mini-GBIC) transceiver module - Gigabit Ethernet
SFP (mini-GBIC) transceiver module - LC/PC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
Gigabit Ethernet
Max Transfer Distance
1 km
1.3 cm x 5.7 cm x 0.9 cm
75 g
90 days warranty
Cisco 3825, 3825 V3PN, 3845, 3845 V3PN, 7301, 7301 VAM2+; Catalyst 2950, 2950ST, 2960, 2960S, 2970G, 3560, 3560G, 3560X, 3750, 3750G; Catalyst Express 500, 500G; CSS 11503; Supervisor Engine 720, II-Plus-TS
Plug-in module
Wired
Cabling Type
1000Base-SX
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1 km
Hot swap module replacement, Digital Optical Monitoring (DOM) support
IEEE 802.3z, IEEE 802.3ah
1 x Ethernet 1000Base-SX - LC/PC multi-mode x 2
Laser Class 1, IEC 60825-1
1.3 cm
5.7 cm
0.9 cm
75 g
Limited warranty - 90 days
-5 °C
85 °C
Cisco 3825, 3825 Branch Office in a Box Bundle, 3825 HVSEC Bundle, 3825 Integrated VoiceVideo, 3825 ISR IP Video Surveillance Bundle, 3825 Retail Bundle, 3825 Secure WAN Optimization Bundle, 3825 SRST Voice Upgrades for HSEC Bundle, 3825 Unified Communications Bundle, 3825 Unified Communications Bundle with Advanced Security, 3825 V3PN Bundle, 3825 Video Encoding Bundle, 3825 VSEC Bundle, 3825 WAN Optimization Bundle, 3825C, 3845, 3845 Branch Office in a Box Bundle, 3845 HVSEC Bundle, 3845 ISR IP Video Surveillance Bundle, 3845 Secure WAN Optimization Bundle, 3845 Unified Communications Bundle, 3845 Unified Communications Bundle with Advanced Security, 3845 V3PN Bundle, 3845 Video Encoding Bundle, 3845 VSEC Bundle, 3845 WAN Optimization Bundle, 3845C, 7301 ITP Signaling Gateway Bundle, 7301 VAM2+ Router Security Bundle , Cisco Catalyst 2950ST-24-LRE, 2950ST-8-LRE, 2960-24LC-S, 2960-24TC-S, 2960-48T, 2960-48TC-L, 2960-8TC-S, 2960S-24TS-S, 2970G-24TS-E, 3560-12PC, 3560-12PC-S, 3560-24PS EMI, 3560-24TS, 3560-24TS EMI, 3560-24TS SMI, 3560-48PS, 3560-48PS EMI, 3560-48PS SMI, 3560-48TS, 3560-48TS EMI, 3560-48TS SMI, 3560G-24PS EMI, 3560G-24PS SMI, 3560G-24TS EMI, 3560G-24TS SMI, 3560G-48, 3560G-48PS EMI, 3560G-48PS SMI, 3560G-48TS EMI, 3560G-48TS SMI, 3560X-48PF-10G, 3750 EMI, 3750 SMI, 3750-24PS, 3750-24PS EMI, 3750-24PS SMI, 3750-24TS, 3750-24TS SMI, 3750-24TS-E, 3750-48PS, 3750-48PS EMI, 3750-48PS SMI, 3750-48TS, 3750-48TS-E, 3750-48TS-S, 3750G-12S-S, 3750G-24S, 3750G-24TS EMI, 3750G-24TS SMI, 3750G-24TS-S, 3750G-48PS, 3750G-48TS-E , Cisco Catalyst Express 500-24LC, 500-24PC, 500G-12TC , Cisco CSS 11503 Content Services Switch , Cisco Supervisor Engine 720, 720 with PFC3B, 720-3BXL, II-Plus-TS
Scroll to top
