BT.com
Wishlist
Cisco SF500-24MP 24-port 10/100 PoE+ Stackable Managed Switch
Cisco SF500-24MP 24-port 10/100...
£770.14
£770.14
Add to wishlist
Delivery
Standard Due date unavailable
The Cisco 500 Series Stackable Managed Switches are a line of stackable managed Ethernet switches that provide the advanced capabilities you need to support a more demanding network environment, at an affordable price. This switc provide 24 ports of Fast Ethernet and 24 of Gigabit Ethernet connectivity, providing a solid foundation for your current business applications, as well as those you are planning for the future. At the same time, these switches are easy to deploy and manage, without a large IT staff. Cisco 500 Series switches are designed to protect your technology investment as your business grows. Unlike switches that claim to be stackable but have elements which are administered and troubleshot separately, the Cisco 500 Series provides true stacking capability, allowing you to configure, manage, and troubleshoot multiple physical switches as a single device and more easily expand your network.
Cisco Small Business SF500-24MP - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 (PoE+) + 2 x combo Gigabit SFP + 2 x SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
375 W
Performance
Switching capacity: 28.8 Gbps , Forwarding performance (64-byte packet size): 9.52 Mpps
ACL rules: up to 2048
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Static IPv4 routing, static IPv6 routing, CIDR
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Flow control, Layer 2 switching, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), reset button, STP Root Guard, Uni-Directional Link Detection (UDLD), DHCP relay, IP-MAC binding, Energy Efficient Ethernet, Class of Service (CoS), Generic Attribute Registration Protocol (GARP), 8MB packet buffer, GARP VLAN Registration Protocol (GVRP), DiffServ Code Point (DSCP) support, 2 fans
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 25.7 cm x 4.4 cm
4.35 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE+
PoE Budget
375 W
Performance
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
256 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, system, PoE, link/activity
24 x 100Base-TX - RJ-45 - PoE+ - 30 W , 1 x console - DB-9 - management , 2 x 1000Base-T - RJ-45 , 4 x 1000Base-X - SFP
Internal power supply
1 x serial cable
Rack Mounting Kit
Included
MTBF
514,157 hours
UL 60950, FCC Part 15 A, CSA 22.2
44 cm
25.7 cm
4.4 cm
4.35 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.82
£11.94
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.61
£54.13
Scroll to top
