BT.com
Wishlist
Cisco SF 200-48 48-PORT 10/100 SMART
Cisco SF 200-48 48-PORT 10/100...
£243.92
Hurry, only 2 left in stock!
£243.92
Add to wishlist
Delivery
Standard 1-3 working days
The key to succeeding in today's competitive business environment is investing resources wisely and getting the most value for your dollars. What if you could achieve business-class security and performance in your small business network without paying for advanced network features your network may not need? Now you can with Cisco 200 series smart switch. When you need to share network resources and connect computers, printers, and servers, but low cost is a top priority, Cisco 200 series switch provides the ideal solution.
Cisco Small Business Smart SF200-48 - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
48 x 10/100 + 2 x combo Gigabit SFP
Performance
Switching capacity: 10.12 Mpps , Forwarding performance (64-byte packet size): 13.6 Gbps
MAC Address Table Size
8000 entries
Jumbo Frame Support
Remote Management Protocol
RMON, HTTP, TFTP
Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, fanless
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
44 cm x 25.7 cm x 4.4 cm
3.4 kg
United Kingdom
Bundled Services
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Fast Ethernet
Ports
Performance
8000 entries
Jumbo Frame Support
RMON, HTTP, TFTP
Encryption Algorithm
MD5
Authentication Method
RADIUS
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Link activity, port transmission speed, system
48 x 100Base-TX - RJ-45 , 2 x 1000Base-T - RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
Mounting Kit
Included
MTBF
267,865 hours
UL 60950, FCC Part 15 A, CSA 22.2
United Kingdom
44 cm
25.7 cm
4.4 cm
3.4 kg
Limited warranty - lifetime , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.78
£11.54
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.26
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£52.82
Scroll to top
