BT.com
Wishlist
Cisco RV110W Wireless N VPN Firewall
Cisco RV110W Wireless N VPN...
£55.30
Hurry, only 3 left in stock!
£55.30
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The Cisco RV110W Wireless-N VPN Firewall combines simple, highly secure wired and wireless connectivity for small offices/home offices and remote workers with a high-speed, 802.11n wireless access point; a 4-port 10/100 Mbps Fast Ethernet switch; an intuitive, browser-based device manager; and support for the Cisco FindIT Network Discovery Utility, at a very affordable price. Its combination of business-class features, support for virtual networks to enable highly secure guest access, simple installation, and top-quality user experience takes basic connectivity for a small business with five or fewer employees to a new level.
Cisco Small Business RV110W - wireless router - 802.11b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Performance
NAT throughput: 90 Mbps , VPN throughput (IPSec): 5 Mbps
Concurrent sessions: 5000 , IPSec VPN tunnels: 5 , PPTP VPN tunnels: 5 , Active VLANs: 4
Network / Transport Protocol
PPTP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP, Bonjour, DDNS
Routing Protocol
RIP-1, RIP-2, IGMP, static IPv6 routing, RIPng
Remote Management Protocol
SNMP 3, HTTP, HTTPS
NAT support, PAT support, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, port mirroring, E-mail alert, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, firmware upgradable, Rapid Spanning Tree Protocol (RSTP) support, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, DNS proxy, port forwarding, IPv4 support, Direct Sequence Spread Spectrum (DSSS)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, UPnP
1 A
15 cm x 15 cm x 3 cm
279 g
English / Europe
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Selectable Channels Qty
13
Performance
Routing Protocol
SNMP 3, HTTP, HTTPS
Encryption Algorithm
Triple DES, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, UPnP, FCC Class B certified, cUL, IC
Status Indicators
Power, WAN, LAN, wireless
Line Properties
Line Coding Format
OFDM
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
2
Directivity
Omni-directional
Gain Level
1.8 dBi
External power adapter
Electric Current Required
1 A
1 x network cable
English / Europe
OS Provided
Linux
Software Included
Drivers & Utilities
15 cm
15 cm
3 cm
279 g
10 - 85% (non-condensing)
Accessories
£4.95
£3.74
£11.19
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.02
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.61
£50.74
Scroll to top
