BT.com
Wishlist
Cisco Rugged SFP (mini-GBIC) Transceiver Module - Gigabit Ethernet
Cisco Rugged SFP (mini-GBIC)...
£662.85
27 in stock
£662.85
Add to wishlist
Delivery
Standard 1-3 working days
The industry-standard Cisco Small Form-Factor Pluggable (SFP) transceiver modules are hot-swappable input/output (I/O) devices that plug into 100BASE, 1000BASE and 10GBASE ports (for SFP+), which connect the module port with the fiber-optic or copper network.
The 1000BASE-LX/LH SFP transceiver module for SMF, compatible with the IEEE 802.3z 1000BASE-LX standard, operates on standard singlemode fiber-optic link spans of up to 10 km and up to 550 m on any multimode fibers. When used over legacy multimode fiber type, the transmitter should be coupled through a mode conditioning patch cable.
Cisco Rugged SFP - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX, 1000Base-LH
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
GigE
1 year warranty
Cisco 3270, 3270 Rugged Integrated Services Router Card
Plug-in module
Wired
Cabling Type
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1 x Ethernet 1000Base-LX - LC single-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
Limited warranty - 1 year
-40 °C
85 °C
Scroll to top
