BT.com
Wishlist
Cisco Power Supply hot-plug/redundant 715 Watt
Delivery
Standard Due date unavailable
For the Catalyst 3750-X and 3560-X Series
Cisco - power supply - hot-plug / redundant - 715 Watt
Power supply - hot-plug / redundant - plug-in module
1.26 kg
Input Voltage
AC 100-240 V
Power Capacity
715 Watt
Input Connectors
Power IEC 60320 C16
8.3 cm x 26 cm x 3.5 cm
Catalyst 3560X-24P-L, 3560X-24P-S, 3560X-24T-L, 3560X-24T-S, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-L, 3560X-48T-S
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Input Connectors
Power IEC 60320 C16
Power Capacity
715 Watt
MTBF
664,055 hours
BSMI, CISPR 22 Class A, GOST, CISPR 24, EN 61000-3-2, VCCI Class A ITE, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EMC, MIC, ICES-003 Class A, EN 61000-4-5, RoHS, EN300-386, UL 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1
-5 °C
45 °C
5 - 90%
8.3 cm
26 cm
3.5 cm
1.26 kg
Cisco Catalyst 3560X-24P-L, 3560X-24P-S, 3560X-24T-L, 3560X-24T-S, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-L, 3560X-48T-S
Scroll to top
