BT.com
Wishlist
Cisco Power supply - Hot-plug/Redundant 440 Watt
Delivery
Standard Due date unavailable
Cisco - Power supply - hot-plug / redundant ( plug-in module ) - -36 - -72 V - 440 Watt - for Catalyst 3560X-24, 3560X-48, 3750X-12, 3750X-24, 3750X-48
Cisco - power supply - hot-plug / redundant - 440 Watt
Power supply - hot-plug / redundant - plug-in module
1.2 kg
Input Voltage
-36 - -72 V
Power Capacity
440 Watt
Input Connectors
2
8.3 cm x 26 cm x 3.5 cm
Input Voltage
-36 - -72 V
Input Connectors
2
Max Electric Current
16 A
Power Capacity
440 Watt
BSMI, CISPR 22 Class A, GOST, CISPR 24, EN 61000-3-2, VCCI Class A ITE, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EMC, MIC, ICES-003 Class A, EN 61000-4-5, RoHS, EN300-386, UL 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1
-5 °C
45 °C
5 - 90% (non-condensing)
8.3 cm
26 cm
3.5 cm
1.2 kg
Cisco Catalyst 3560X-24P-L, 3560X-24P-S, 3560X-24T-L, 3560X-24T-S, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-L, 3560X-48T-S, 3750X-12S-E, 3750X-12S-S, 3750X-24P-L, 3750X-24P-S, 3750X-24S-E, 3750X-24S-S, 3750X-24T-L, 3750X-24T-S, 3750X-48PF-L, 3750X-48PF-S, 3750X-48P-L, 3750X-48P-S, 3750X-48T-L, 3750X-48T-S
Scroll to top
