BT.com
Wishlist
Cisco Outdoor Omnidirectional Antenna for 2G/3G Cellular
Cisco Outdoor Omnidirectional...
£168.58
42 in stock
£168.58
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco Outdoor Omnidirectional Antenna for 2G/3G/4G Cellular antenna is designed to cover domestic LTE700/Cellular/PCS/AWS/MDS, WiMAX 2300/2500, and GSM900/GSM1800/UMTS/LTE2600 bands and is supported on the Cisco CGR 2010, 1240, and the 1120 routers.
The Omnidirectional Outdoor Antenna is compatible with Cisco 2G, 3G, and 4G cellular devices that use a Type N connector and requires a mast-mounted outdoor antenna.
Cisco Outdoor Omnidirectional Antenna for 2G/3G Cellular - antenna
Antenna
2.5 cm 24.9 cm
0.68 kg
Product Material
Polycarbonate
Aerial Placing / Mounting
Outdoor
Frequency Range
1.71 - 2.17 GHz, 2.3 - 2.7 GHz, 698 - 960 MHz
Gain
1.5 dBi (for 698 - 960 MHz), 3.5 dBi (for 1.71 - 2.7 GHz)
Directivity
Omni-directional
RoHS
Cisco 2010, 2010 Connected Grid
Antenna
Product Material
Polycarbonate
2.5 cm
24.9 cm
0.68 kg
Enclosure Colour
White
Aerial
Outdoor
Frequency Range
Gain
Directivity
Omni-directional
Voltage Standing Wave Ratio (VSWR)
2.5:1 (for 698 - 960 MHz), 2.0:1 (for 1710 - 2690 MHz)
Cabling & Wiring
Connector Provided
1 x N-Series connector female
Mounting Kit
Included
RoHS
-30 °C
70 °C
Scroll to top
