BT.com
Wishlist
Cisco OneX Converter Module
£141.73
£141.73
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco OneX Converter Module offers investment protection for 10 Gigabit Ethernet X2 ports of Cisco switches by enabling migration from X2 to Small Form-Factor Pluggable Plus form factor without having to upgrade the switches or modules.
The OneX Converter Module converts a 10 Gigabit Ethernet X2 port into a 10 Gigabit Ethernet SFP+ port. With the OneX Converter Module, customers have the flexibility to use the 10 Gigabit X2 interface port of a switch with X2 modules or SFP+ modules. This flexibility is critical when the specific type of interface is not available in one or the other form factor or when customers want to use the same form factor for interfaces across multiple platforms deployed in their network.
Cisco OneX Converter Module - X2 transceiver module - 10 Gigabit Ethernet
Plug-in module
Cabling Type
10GBase-X
Data Transfer Rate
10 Gbps
10 Gigabit Ethernet
4.2 cm x 9.8 cm x 1.9 cm
300 g
90 days warranty
Catalyst 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD
Plug-in module
Wired
Cabling Type
10GBase-X
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Expansion Slots
1 (total) / 1 (free) x SFP+
Compatible Slots
1 x X2
4.2 cm
9.8 cm
1.9 cm
300 g
Limited warranty - 90 days
Cisco Catalyst 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD
Scroll to top
