BT.com
Wishlist
Cisco Nexus 2248TP-E Fabric Extender Expansion Module
Cisco Nexus 2248TP-E Fabric...
£5,933.44
£5,933.44
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco Nexus 2248TP-E Fabric Extender is a 1 Gigabit Ethernet fabric extender with enhancements that target workloads such as large-volume databases, distributed storage, and video editing. The Cisco Nexus 2248TP-E supports 48 100/1000BASE-T host facing ports and four 10 Gigabit Ethernet fabric interfaces.
Cisco Nexus 2248TP-E Fabric Extender - expansion module
Expansion module
Rack-mountable
Ports
Gigabit Ethernet x 48 + 10 Gigabit SFP+ x 4
43.94 cm x 44.96 cm x 4.37 cm
8 kg
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T
Auxiliary Ports
4 x SFP+ (uplink)
100Mb LAN, GigE
Performance
Forwarding performance (full duplex): 80 Gbps , Forwarding performance: 176 Gbps , Forwarding performance: 131 Mpps
ACL entries: 256 , Policies: 64
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an
1 year warranty
Nexus 5010, 5020, 5020,, 5548, 5548P, 5548UP, 5596T, 5596UP, 6001, 6001P, 6001T, 6004, 6004 24, 6004EF, 7004, 7009, 7010, 7700, 7700 18, 7700 18-Slot, 7700 6, 7700 6-Slot, 7706, 7710
Expansion module
Rack-mountable
Ports
Wired
Cabling Type
100Mb LAN, GigE
Auxiliary Ports
4 x SFP+ (uplink)
Performance
Remote Management Protocol
SNMP 1, SNMP 2, RMON, SNMP 3, CLI
Status Indicators
Port status, power, system, module locator, fan
Flow control, full duplex capability, auto-negotiation, VLAN support, Cisco Gigabit EtherChannel, Syslog support, Weighted Round Robin (WRR) queuing, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, Management Information Base (MIB), Class of Service (CoS), tagged VLAN, Virtual PortChannel (vPC) technology, hot swappable power supply
Expansion Slots
4 (total) / 4 (free) x SFP+
48 x 1000Base-T - RJ-45
CISPR 22 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, EN50082-1, EN 61000-6-1, AS/NZS 60950-1, ICES-003 Class A, FCC CFR47 Part 15, EN300-386, UL 60950-1, IEC 60950-1, EN 60950-1, RoHS, CSA C22.2 No. 60950-1, Directive 2004/108/EC, Directive 2006/95/EC, VCCI Class A, CNS 13438(95) Class A, KN22 Class A, GB4943.1-2011
Power supply - hot-plug / redundant - plug-in module
43.94 cm
44.96 cm
4.37 cm
8 kg
Limited warranty - advance parts replacement - 1 year
5 - 95% (non-condensing)
Cisco Nexus 5010, 5010 OSM version, 5010 Solutions Kit, 8G FC Unified Fabric, 5020, 5020 Solutions Kit, 8G FC Unified Fabric, 5020, IBM OSM version, 5548 Storage Solutions Bundle, 5548P, 5548UP, 5548UP in N5548UP-N2K Bundle, 5548UP Storage Solutions Bundle, 5596T, 5596UP, 5596UP Storage Solutions Bundle, 6001, 6001P, 6001T, 6004, 6004 24 x 40GE Ports/FCoE Bundle, 6004EF, 7004 Bundle, 7009, 7010, 7010 Bundle, 7700 18 Slot Chassis, 7700 18-Slot Switch 220 Gbps/Slot Fabric Module, 7700 6 Slot Chassis, 7700 6-Slot Switch 220 Gbps/Slot Fabric Module, 7700 Switches 10-Slot Chassis, 7700 Switches 10-Slot Switch 220 Gbps/Slot Fabric Module, 7706, 7710, 7710 Bundle
Scroll to top
