BT.com
Wishlist
Cisco Module/10GBASE-SR X2
£966.56
11 in stock
£966.56
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco 10GBASE X2 modules offer customers a wide variety of 10 Gigabit Ethernet connectivity options for data center, enterprise wiring closet, and service provider transport applications.
The Cisco 10GBASE-SR Module supports a link length of 26 m on standard FDDI grade MMF. Using 2000 MHz km*MMF (OM3), up to 300 m link lengths are possible.
Cisco X2 - X2 transceiver module - 10 GigE
X2 transceiver module - SC/PC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10 GigE
Max Transfer Distance
300 m
3.6 cm x 9.1 cm x 1.3 cm
90 days warranty
Cisco 8-Port 10; Catalyst 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD, 4500, 4948 10; ME 4924-10GE; Supervisor Engine II-Plus-10GE
Plug-in module
Wired
Cabling Type
10GBase-SR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
IEEE 802.3ae
1 x Ethernet 10GBase-LR - SC/PC multi-mode x 2
Compatible Slots
1 x X2
3.6 cm
9.1 cm
1.3 cm
Limited warranty - 90 days
70 °C
Cisco 8-Port 10 Gigabit Ethernet Module with DFC3C, 8-Port 10 Gigabit Ethernet Module with DFC3CXL , Cisco Catalyst 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3750E-24PD, 3750E-24TD, 3750E-48PD, 3750E-48PD-F, 3750E-48TD, 4500 Series Supervisor Engine V-10GE, 4948 10 Gigabit Ethernet Switch , Cisco ME 4924-10GE , Cisco Supervisor Engine II-Plus-10GE
Scroll to top
