Click to visit BT.com
BT.com
Wishlist
Cisco LC connector SX transciever
Quicklinx: 7B0YWS00
Mfr#: GLC-SX-MM=
The industry-standard Cisco Small Form-factor Pluggable (SFP) Gigabit Interface Converter is a hot-swappable input/output device that plugs into a Gigabit Ethernet port or slot, linking the port with the network. The 1000BASE-SX SFP is compatible with the IEEE 802.3z 1000BASE-SX standard and operates on 50 micrometer multimode fiber links up to 550 m and on 62.5 micrometer FDDI-grade multimode fibers up to 220 m.
Cisco - SFP (mini-GBIC) transceiver module - Gigabit Ethernet
SFP (mini-GBIC) transceiver module - LC/PC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
Gigabit Ethernet
Max Transfer Distance
550 m
1.3 cm x 5.7 cm x 0.9 cm
75 g
90 days warranty
Cisco 3825, 3825 V3PN, 3845, 3845 V3PN, 5508, 7301, 7301 VAM2+; ASA 5512, 5515, 5525, 5545, 5555; Catalyst 2950, 2960, 2970, 3560, 3750, 4500, 4948; Catalyst Compact 2960; Catalyst Express 500; CSS 11503, 11506; ME 2400, 3400, 4924, 6524; Supervisor Engine 720, II-Plus-TS
Plug-in module
Wired
Cabling Type
1000Base-SX
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Hot swap module replacement
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC/PC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
1.3 cm
5.7 cm
0.9 cm
75 g
Limited warranty - 90 days
70 °C
Cisco 3825, 3825 Branch Office in a Box Bundle, 3825 Integrated VoiceVideo, 3825 Secure WAN Optimization Bundle, 3825 Voice Security Bundle, 3825 WAN Application Acceleration Bundle, 3825 WAN Optimization Bundle, 3845, 3845 Branch Office in a Box Bundle, 3845 Secure WAN Optimization Bundle, 3845 Voice Security Bundle, 3845 WAN Application Acceleration Bundle, 3845 WAN Optimization Bundle, 5508 Wireless Controller, 7301 ITP Signaling Gateway Bundle, 7301 VAM2+ Router Security Bundle , Cisco ASA 5512-X Firewall Edition, 5515-X Firewall Edition, 5525-X Firewall Edition, 5545-X Firewall Edition, 5545-X IPS Edition, 5555-X Firewall Edition, 5555-X IPS Edition , Cisco Catalyst 2960-24LC-S, 2960-24PC-L, 2960-24PC-S, 2960-24TC, 2960-24TC-L, 2960-24TC-S, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC, 2960-48TC-L, 2960-48TC-S, 2960-8TC, 2960-8TC-S, 2960G-24TC, 2960G-48TC, 2960G-8TC, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S, 2970G-24TS-E, 3560-12PC, 3560-12PC-S, 3560-24TS, 3560-24TS EMI, 3560-24TS SMI, 3560-48TS, 3560-48TS EMI, 3560-48TS SMI, 3560-8PC, 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3560G-24PS EMI, 3560G-24PS SMI, 3560G-24TS EMI, 3560G-24TS SMI, 3560G-48, 3560G-48PS EMI, 3560G-48TS EMI, 3560V2-24PS, 3560V2-24TS, 3560V2-24TS-SD, 3560V2-48PS, 3560V2-48TS, 3560X-24P-L, 3560X-24P-S, 3560X-24T-L, 3560X-24T-S, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-L, 3560X-48T-S, 3750-24FS, 3750-24TS SMI, 3750G-12S, 3750G-12S-S, 3750G-24PS-E, 3750G-24PS-S, 3750G-48PS-E, 3750G-48PS-S, 3750G-48TS-E, 3750G-48TS-S, 4500 Series Supervisor Engine V-10GE , Cisco Catalyst Compact 2960C-8TC-L , Cisco Catalyst Express 500-24LC, 500-24PC, 500G-12TC , Cisco ME 2400-24TS, 3400-24TS, 4924-10GE, 6524 Ethernet Switch
