BT.com
Wishlist
Cisco IP Telephony Gateway with 4 FX
Cisco IP Telephony Gateway with 4...
£268.98
Hurry, only 3 left in stock!
£268.98
Add to wishlist
Delivery
Standard 1-3 working days
Developed for small businesses, the Cisco SPA8800 IP Telephony Gateway adapts to the needs of businesses that maintain their own on-premise IP private branch exchange (PBX) or that want to add voice over IP (VoIP) to their legacy time-division multiplexing (TDM) PBX or key system. The SPA8800 can be configured to be a FXO gateway for an asterisk open source PBX, providing a versatile solution when conditions favor an external device.
Powered by industry-leading VoIP technology from Cisco, the SPA8800 is designed with a solid hardware casing and contains many standard features, including four RJ-11 FXS and four FXO ports, a 10/100BASE-T RJ-45 Ethernet interface to connect to either a router or multilayer switch, and an auxiliary port for local administration. The gateway also includes a single multiport RJ-21 50-pin connector, offering an alternative connection choice for FXO and FXS ports when deploying the gateway in varied environments.
The SPA8800 features a high level of security by implementing state-of-the-art technologies to provide standards-based encryption protocols. The gateway's provisioning capabilities give service providers a secure mechanism not for only remotely managing the device, but also for installing software upgrades without interrupting service and obtaining performance measurements and troubleshooting information.
The Cisco SPA8800 is an affordable IP telephony gateway solution that is ideal for small business environments that have VoIP service and also require a connection to the public switched telephone network (PSTN). It can be used with existing analog telephones and teleconferencing equipment, enabling small business customers to protect and extend their investments.
Cisco Small Business Pro SPA8800 IP Telephony Gateway - VoIP phone adapter
VoIP phone adapter
External
Ethernet, Fast Ethernet
VoIP Protocols
SIP v2
Telephony Interfaces
4 phone (FXS), 4 line (FXO)
22 cm x 17 cm x 3.9 cm
1.3 kg
1 year warranty
VoIP phone adapter
22 cm
17 cm
3.9 cm
1.3 kg
External
Wired
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE
Remote Management Protocol
HTTP, HTTPS
DHCP support, ARP support, Syslog support, DiffServ support, VPN passthrough, SNTP support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), DHCP server, port forwarding
Encryption Algorithm
MD5, TLS, PEAP, TTLS, 256-bit AES
Authentication Method
Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.1p
IP Telephony
VoIP Protocols
SIP v2
Voice Codecs
G.711, G.723.1, G.729a, G.726, T.38
IP Telephony Features
Comfort noise generation (CNG), voice activity detection (VAD), call forwarding, Caller ID, call waiting, call transfer, silence suppression, DTMF generation/detection
4 x modem - RJ-11 , 4 x modem - RJ-11 , 1 x 100Base-TX - RJ-45 (WAN) , 1 x phone line
1 x network cable , 4 x phone cable
EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, CS-03, UL 60950-1, IEC 60950-1
External power adapter
Limited warranty - 1 year
45 °C
10 - 90%
Scroll to top
