BT.com
Wishlist
Cisco Industrial Ethernet 3000 Series 8 Ports Managed 2x Combo Gigabit SFP Switch
Cisco Industrial Ethernet 3000...
£1,351.53
£1,351.53
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco Industrial Ethernet 3000 (IE 3000) Series Switches are a new family of switches that provide a rugged, easy-to-use, secure switching infrastructure for harsh environments. The Cisco IE 3000 family features industrial design and compliance, tools for ease of deployment, management, and replacement; and network security based on open standards. The Cisco IE 3000 is an ideal product for industrial Ethernet applications, including factory automation, intelligent transportation systems (ITSs), substations, and other deployments in harsh environments.
Cisco Industrial Ethernet 3000 Series - switch - 8 ports - Managed
Switch - 8 ports - L2+ - Managed
Subtype
Fast Ethernet
Ports
8 x 10/100 + 2 x combo Gigabit SFP
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH-2
Layer 2 switching, VLAN support, IGMP snooping, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), Dynamic ARP Inspection (DAI)
IEEE 802.1D, IEEE 802.3ad (LACP), IEEE 802.1x
15.2 cm x 11.2 cm x 14.7 cm
2 kg
1 year warranty
Bundled Services
1 year warranty
Enclosure Type
DIN rail mountable
Subtype
Fast Ethernet
Ports
8K entries
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
128 MB
Flash Memory
64 MB Flash
Status Indicators
Port status, system
8 x 100Base-TX - RJ-45 , 2 x 1000Base-T - RJ-45 , 2 x SFP (mini-GBIC)
Rack Mounting Kit
Optional
MTBF
329,451 hours
UL, BSMI CNS 13438 Class A, CISPR 24, cUL, EN55022, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, NOM, VCCI Class A ITE, IEC 60950, EN55024, CISPR 22, CB, MIC, AS/NZS 3548, EN 50081-2, EN 50082-2, UL 60950-1, IEC 60950-1, CSA C22.2 No. 60950-1-03, UL 508, FCC Part 15 A, CSA C22.2 No. 60950-1
Software Included
Cisco IOS LAN Base
15.2 cm
11.2 cm
14.7 cm
2 kg
Limited warranty - 1 year
-40 °C
75 °C
10 - 95%
Accessories
£4.95
£3.84
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.42
£52.93
Scroll to top
