BT.com
Wishlist
Cisco EHWIC Expansion Module
£605.38
More than 50 in stock
£605.38
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco Gigabit Ethernet dual-identity Enhanced High-speed WAN Interface Card (EHWIC) brings both Small Form-factor Pluggable (SFP) and copper (RJ-45) Gigabit Ethernet connectivity to Cisco Integrated Services Routers (ISRs) to accelerate applications such as Ethernet WAN access, inter-VLAN routing (IVR), and high speed connectivity to LAN switches.
The single-port Cisco Gigabit Ethernet EHWIC provides Gigabit Ethernet optical and copper connectivity in a compact form factor to the Cisco Integrated Service Router Generation 2 (ISR G2).
The Gigabit Ethernet EHWIC enables branch offices to cost-effectively use high-speed uplinks in numerous environments. The enhanced performance of Gigabit Ethernet in Cisco ISR G2 routers enables applications and services and provides greater capacity for existing IVR and bridging capabilities. Branch offices can connect to Ethernet WAN (EWAN) Layer 2 and 3 services.
Cisco - expansion module
Expansion module
Plug-in module
Interface (Bus) Type
EHWIC
7.9 cm x 12.2 cm x 2.1 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 1000Base-X
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
IEEE 802.2, IEEE 802.3, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
Cisco 1921, 1921 4-pair, 1921 ADSL2+, 1941, 2901, 2911, 2921, 2951, 3925, 3925E, 3945, 3945E
Expansion module
Plug-in module
EHWIC
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Remote Management Protocol
SNMP, RMON
Flow control, VLAN support, Cisco Gigabit EtherChannel , MAC address filtering, Weighted Random Early Detection (WRED), Access Control List (ACL) support, Quality of Service (QoS), Committed Access Rate (CAR), Jumbo Frames support
Expansion Slots
1 x SFP
1 - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
Compatible Slots
1 x EHWIC
EN 61000-3-2, VCCI Class A ITE, EN 61000-3-3, EN55022 Class A, ICES-003 Class A, EN300-386, FCC Part 15 A
7.9 cm
12.2 cm
2.1 cm
10 - 90% (non-condensing)
Cisco 1921, 1921 4-pair G.SHDSL bundle, 1921 ADSL2+ Annex M Bundle, 1921 ADSL2+ Bundle, 1921 SEC T1 Bundle, 1941, 1941 Mobile Wireless, 1941 Secure WAAS Bundle, 1941 Security, 1941 Security Bundle, 1941 SRE Bundle, 1941 WAAS Bundle, 2901, 2901 Secure WAAS Bundle, 2901 Security Bundle, 2901 SRE Bundle, 2901 Terminal Server Bundle, 2901 Voice Bundle, 2901 Voice Security and CUBE Bundle, 2901 Voice Security Bundle, 2901 WAAS Bundle, 2911, 2911 Secure WAAS Bundle, 2911 Security Bundle, 2911 SRE Bundle, 2911 UCSE Bundle, 2911 Voice Bundle, 2911 Voice Security and CUBE Bundle, 2911 Voice Security Bundle, 2911 WAAS Bundle, 2921, 2921 Secure WAAS Bundle, 2921 Security Bundle, 2921 SRE Bundle, 2921 Voice Bundle, 2921 Voice Security and CUBE Bundle, 2921 Voice Security Bundle, 2921 WAAS Bundle, 2951, 2951 Secure WAAS Bundle, 2951 Security Bundle, 2951 SRE Bundle, 2951 Voice Bundle, 2951 Voice Security and CUBE Bundle, 2951 Voice Security Bundle, 2951 WAAS Bundle, 3925, 3925 Security Bundle, 3925 SRE Bundle, 3925 Voice Bundle, 3925 Voice Security and CUBE Bundle, 3925 Voice Security Bundle, 3925 WAAS Bundle, 3925E, 3925E Security Bundle, 3925E SRE Bundle, 3925E Voice Bundle, 3925E Voice Security and CUBE Bundle, 3925E Voice Security Bundle, 3945, 3945 PSRE Bundle, 3945 Security Bundle, 3945 SRE Bundle, 3945 Voice Bundle, 3945 Voice Security and CUBE Bundle, 3945 Voice Security Bundle, 3945 WAAS Express Bundle, 3945E, 3945E Security Bundle, 3945E SRE Bundle, 3945E Voice Bundle, 3945E Voice Security and CUBE Bundle, 3945E Voice Security Bundle
Scroll to top
