BT.com
Wishlist
Cisco Dual-Band Single Radio Access Point w/PoE (ETSI)
Cisco Dual-Band Single Radio Access...
£165.43
More than 50 in stock
£165.43
Add to wishlist
Delivery
Standard 1-3 working days
The Cisco WAP321 is a sleek, high-performance, and easy to deploy selectable band Wireless-N access point that delivers fast, reliable wireless connectivity and allows small businesses to easily expand their wired networks. This device combines ease of use with business-class features such as a Gigabit Ethernet LAN port, support for IPv6, Power over Ethernet for simpler deployment, quality of service to prioritize network traffic, and comprehensive security to deliver the reliability and performance needed for small business networks. The elegant design has flexible mounting options that allow it to seamlessly blend into any small business environment. It can be managed with an intuitive browser-based GUI.
Cisco Small Business WAP321 - radio access point
Radio access point
External
Japan, Korea, Russia, Europe
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
17 cm x 17 cm x 3.5 cm
275 g
Radio access point
17 cm
17 cm
3.5 cm
275 g
External
Wireless
Data Transfer Rate
300 Mbps
Spread Spectrum Method
OFDM
Network / Transport Protocol
DHCP, Bonjour
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, LAN, wireless
DHCP support, load balancing, VLAN support, Syslog support, E-mail alert, IPv6 support, Wireless Distribution System (WDS) support, firmware upgradable, wall mountable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), Multiple SSID support, wireless bridge mode, IPv4 support
Encryption Algorithm
WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
Antenna
Internal
Gain Level
2 dBi
1 x 1000Base-T - RJ-45
1 x network cable
Mounting Kit
Included
FCC Class B certified, IC
PoE
OS Provided
Linux
Limited warranty - lifetime
10 - 85% (non-condensing)
Scroll to top
