BT.com
Wishlist
Cisco Catalyst Compact Managed Switch
Delivery
Standard Due date unavailable
The Cisco Catalyst 2960-C series compact switch is a small form-factor Fast Ethernet and Gigabit Ethernet switch designed for deployments outside the wiring closet. Enterprise and commercial customers can deliver advanced security services, unified communications, wireless, IP video cameras, and other applications for the office workspace, micro branch office, classroom, cruise ship, and other wiring-constrained environments.
Cisco Catalyst Compact 2960CG-8TC-L - switch - 8 ports - Managed
Switch - 8 ports - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x shared SFP
Performance
Forwarding performance (64-byte packet size): 13.2 Mpps , Forwarding performance: 10 Gbps
Virtual interfaces (VLANs): 255
Jumbo Frame Support
9018 bytes
Routing Protocol
RIP-1, RIP-2
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Dynamic ARP Inspection (DAI), STP Root Guard, Uni-Directional Link Detection (UDLD), fanless, DHCP relay, Remote Switch Port Analyzer (RSPAN)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae, IEEE 802.1ab (LLDP)
26.9 cm x 21.3 cm x 4.4 cm
1.35 kg
Bundled Services
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
Performance
Jumbo Frame Support
9018 bytes
Routing Protocol
RIP-1, RIP-2
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
64 MB
10 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB - Type A , 1 x console - mini-USB Type B - management , 1 x RS-232 - RJ-45 - management , 2 x SFP (mini-GBIC)
Internal power supply
MTBF
542,482 hours
GOST, CISPR 24, EN55022, VCCI Class A ITE, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, GB 4943
Software Included
Cisco IOS LAN Base
26.9 cm
21.3 cm
4.4 cm
1.35 kg
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 5 years
-5 °C
5 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.84
£11.78
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.42
£53.30
Scroll to top
