BT.com
Wishlist
Cisco Catalyst Compact 3560C-8PC-S 8-port Managed Switch
Delivery
Standard Due date unavailable
The Cisco Catalyst 3560-C series compact switch is a small form-factor Gigabit Ethernet and Fast Ethernet switch designed for deployments outside the wiring closet. Enterprise and commercial customers can deliver advanced security services, unified communications, wireless, IP video cameras, and other applications for the office workspace, branch office, classroom, cruise ship, and other wiring-constrained environments.
Cisco Catalyst Compact 3560C-8PC-S - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
124 W
Performance
Forwarding performance (64-byte packet size): 4.2 Mpps , Forwarding performance: 10 Gbps
Virtual interfaces (VLANs): 1005
Jumbo Frame Support
9018 bytes
Routing Protocol
OSPF, RIP-1, RIP-2, OSPFv2
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Port Aggregation Protocol (PAgP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Dynamic ARP Inspection (DAI), Uni-Directional Link Detection (UDLD), fanless, DHCP relay, Link Aggregation Control Protocol (LACP), Remote Switch Port Analyzer (RSPAN)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ae, IEEE 802.1ab (LLDP), IEEE 802.3at
26.9 cm x 21.3 cm x 4.44 cm
1.86 kg
Bundled Services
Enclosure Type
Desktop, rack-mountable, wall-mountable 1U
Subtype
Fast Ethernet
Ports
PoE+
PoE Budget
124 W
Performance
Jumbo Frame Support
9018 bytes
Routing Protocol
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
64 MB
Status Indicators
Port status, system, link/activity
2 x 1000Base-T - RJ-45 , 8 x 100Base-TX - RJ-45 - PoE+ , 1 x management (mini-USB) - Type B , 1 x management (RS-232) - RJ-45 , 2 x - SFP - uplink , 1 x USB - Type A
Internal power supply
MTBF
373,635 hour(s)
GOST, CISPR 24, EN55022, VCCI Class A ITE, EN55024, CISPR 22, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, GB 4943
Software Included
Cisco IOS IP Base
26.9 cm
21.3 cm
4.44 cm
1.86 kg
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 5 years
-5 °C
5 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.84
£11.41
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.16
£51.70
Scroll to top
