BT.com
Wishlist
Cisco Catalyst 6500 48-port 10/100/1000 GE Module
Cisco Catalyst 6500 48-port...
£15,399.18
£15,399.18
Add to wishlist
Delivery
Standard Due date unavailable
Cisco is the worldwide leader in networking for the Internet. Cisco provides the broadest line of solutions for transporting data, voice and video within buildings, across campuses, or around the world. Cisco solutions ensure that networks both public and private operate with maximum performance, security, and flexibility.
Cisco Express Forwarding 720 Interface Module - switch - 48 ports - Managed - plug-in module
Switch - 48 ports - Managed
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
Performance
Bandwidth: 720 Gbps
Jumbo Frame Support
9216 bytes
Routing Protocol
HSRP, VRRP
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP
Full duplex capability, auto-negotiation, VLAN support, Cisco Gigabit EtherChannel, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), Jumbo Frames support, Time Domain Reflectometry (TDR), Per-VLAN Spanning Tree Plus (PVST+), Per-VLAN Rapid Spanning Tree (PVRST)
IEEE 802.3, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s
35.6 cm x 40.6 cm x 3 cm
Catalyst 6503, 6506, 6509, 6509-NEB, 6513
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Compatible Slots
1 x Expansion Slot
Ports
48 x 10/100/1000
Performance
Bandwidth: 720 Gbps
Jumbo Frame Support
9216 bytes
Routing Protocol
HSRP, VRRP
Status Indicators
Port status, power, Boot State, fail, link/activity
48 x 1000Base-TX - RJ-45
CISPR 22 Class A, CISPR 22 Class B, EN 60950, IEC950, UL 1950, VCCI Class A ITE, EN55022 Class A, EN55022 Class B, AS/NZS 3260, FCC CFR21 Part 1040, FCC Part 15 A, CSA C22.2 No. 950, AS/NZS 3548 Class B, AS/NZS 3548 Class A
35.6 cm
40.6 cm
3 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
75 °C
Max Altitude Operating
4 km
Cisco Catalyst 6503, 6506, 6509, 6509-NEB, 6513
Scroll to top
