BT.com
Wishlist
Cisco CATALYST 4500 E-SERIES
£14,681.66
£14,681.66
Add to wishlist
Delivery
Standard Due date unavailable
Establishing borderless leadership is now easier than ever to achieve with the Cisco Supervisor Engine 7-E, an enterprise-class borderless network access and aggregation supervisor engine. Cisco Supervisor Engine 7-E is built with price-performance aggregation deployments in mind, providing increased Gigabit Ethernet and 10 Gigabit Ethernet fiber density along with hardware capabilities to support enterprise-class aggregation functionalities. Supervisor Engine 7-E facilitates borderless user experiences for enterprise, public sector, mid-market, and commercial customer deployment business-critical applications.
Cisco Supervisor Engine 7-E - control processor
Control processor
Plug-in module
1.5 GHz
RAM
2 GB (installed) / 4 GB (max)
Performance
Switching capacity: 848 Gbps , Per-slot switching capacity: 48 Gbps , IPv6 routing: 125 Mbps , IPv4 routing: 250 Mbps
QoS hardware entries: 128000 , Security services entries: 128000 , Virtual interfaces (VLANs): 4096 , Multicast entries (IPv4): 70000 , Multicast entries (IPv6): 64000 , Multicast entries (shared between IPv4 and IPv6): 16000 , MAC addresses: 55000 , IPv6 routes: 128000 , IPv4 routes: 256000 , Spanning Tree Protocol instances: 3000 , Switched virtual interfaces (SVIs): 4096 , NetFlow entries: 128000
Control processor
Processor / Memory / Storage
Processors Installed
1.5 GHz
RAM
2 GB (4 GB max) SDRAM
Plug-in module
Wired
Routing Protocol
PIM-SM, PIM-DM, PIM-SSM
Performance
Uplink, IPv6 support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping
Communications
Supported Flash Memory Cards
SD Memory Card
Expansion Slots
4 (total) / 4 (free) x SFP+
1 x management - RJ-45 , 1 x 1000Base-T (management) - RJ-45 , 1 x USB - Type A
Compatible Slots
1 x Expansion Slot
NEBS level 3, CISPR 22 Class A, EN 61000-3-2, EN55022, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950, EN50082-1, CSA 22.2 No. 60950, EN 61000-6-1, AS/NZ 3548 Class B, AS/NZS 3260, ICES-003 Class A, FCC Part 15 A
Limited warranty - lifetime
10 - 90% (non-condensing)
Other bundles
£14,681.66
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£14,685.14
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.31
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.24
£14.80
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£28.46
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.45
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£31.83
£50.76
Scroll to top
